The temperature will go down to 35 degrees the rise to over 45 degrees. Three days ago the refrigerator rose to over 55 degrees. We emptied it, tuned it off for 24 hours then turned it back on, this is what Heartland told us to do last time this happened. Now it seems to stay between 35 and 45 degrees. Is this an acceptable range?
How long does this temperature issue last? When you notice this issue how long does this sit at the hire temp, 1 hour? I am trying to understand why Heartland/Marvel would ask you to turn it off. Please let me know. Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
SOURCE: Refrigerator temperature climbs and takes too long to recover.
Look at following areas for the model number
SOURCE: Extreme rise in refrigerator temperature
You probably have a bad light switch or the door may be sagging. interior lights are definetly staying on with door closed.
SOURCE: My GE Refrigerator model GSL25JTFBBS stay in
Good day,
35 minutes would be considered nominal. That is the amount of time needed to heat up the cooling coils behind the rear panel in the freezer compartment, and then allow it to drain the condensate water out the drain.
The defrost cycle is made up of 2 parts.
The first part involves shutting all fans and compressor off, and turning on the heater/heaters mounted on the bottom of the cooling coil to above freezing. About 10 to 15 minutes.
The second half occures when a defrost thermostat mounted on the top of that coil senses the coil is above freezing. It cuts the power to the heaters, and lets the system just idle, while the water is allowed to drain out of the drain.
If that tstat is working properly, the food temperature is affected slightly but never to an above freezing condition.
The thermostat is a small 1" round disk clipped to the top of the coil.
Only one possibility, but that tstat could be hanging allowing the freezer coil compartment to reach a very high temperature. If so, it needs replaced.
You should also check to see if both fans and compressor start running as soon as the cycle is done.
SOURCE: Refrigerator temperature will not stay
have you done a continuity test on the t-stat and the heater also when you did replace the fan did you assure that you defrosted the airport holes that go from the freezer to the fridge area lastly if the t-stat and the heater check out to be working properly then you might have a sensor problem but first check out the tstat this is usually the first thing that goes on fridgerators please remember to rank how this opinion helped in your appliance situation and if i can aswer anything futher please message me back thank you again
rickead1
