Battery Sharkshttps://www.batterysharks.com > mpv5_b12-35_x2
The Hoveround MPV5 wheelchair requires 2 batteries - SP12-35 NB (12 V 35 AH). Please note that you need to use all existing cables and hardware from your ...
US$110.98 · In stock
Fast UPS Delivery. Click on the Picture for More Information. Learn More ' Add to Compare · Shoprider HD Power Wheelchair Replacement Battery (2 Batteries)
I DON'T KNOW. COULD BE UNDER WARRANTY FOR FREE REPAIR OR REPLACEMENT. I HAVE RYOBI AND UPDATED ITEMS. THEY HAVE 3 CHARGERS 2 SMALLER RATED CHARGERS WOULD NOT GIVE ME
'FULL CHARGED' LIGHT. OLD BATTERIES WOULD NOT CHARGE ON OLDER CHARGER. FROM INTERNET ADVICE, I REPEATEDLY PLUG AND UNPLUG CHARGER BY HAVING PLUG LOOSE WHEN DOING THIS. SOMETIMES IT TAKES 4 TIMES TO CHANGE FROM DEFECTIVE TO CHARGE. SOMETIMES IT TAKES 20 TIMES TO SEE THE CHARGE LIGHT.
Absolutely. Let me explain what "Ah" means. "Ah" stands for Amp Hours. A 32ah battery will run a 1 amp motor for 32 hours...or a 32 amp motor for one hour...a 16 amp motor for two hours etc.. As long as the battery voltage is the same it's absolutely fine. As long as your chargers are the correct voltage, they'll be fine as well. So basically, the higher the "Ah", the longer the battery will last. This is why higher "Ah" batteries are more expensive. Hope this helps : )
