Please e-mail at [email protected]
L
here is the link for the honda GCV160 engine. http://lawnandgarden.manualsonline.com/manuals/mfg/honda_1_2/gcv160_2.html
There must be another model number for the pressure washer. Check the pressure washer again and search that model on manualsonline.com
SOURCE: I can't find an oil drain plug on a honda 5.5hp engine.gvc 160.
The engine drain plug is on the main (square) base part of the cylinder block. I think it is 10mm. There is a compression washer to seal it aswell so it might need a bit of extra pressure to start it undoing. This should drain your block almost completely.
For diagrams go here, you will need the engine serial number and prefix.
http://www.honda-engines-eu.com/en/welcome.html
For manuals go here,
http://www.honda-engines.com/Engines_owners_manuals/own.htm
SOURCE: My almost new Honda GCV 160 engine will not start.
Hi , I think you need someone to remind you these engins are not made by god and they work by obeying three simple rules ,
1.Spark , Can you see a very good blue spark
2.compression,,can you feel strong compression ,
3.fuel , is the right amount of fuel getting in , is the air mixture good ,
Now try these things
Find the manual and PROPPER set the gap in the spark plug ,
clean and check the air filter ,
remove all fuel and replace with brand new,
check the fuel filter,even in the tank tap?
undo the screw at the carb bowl , can you see petrol leaking ,
If everything checks out then try this to get it started,,
spray "easystart" in the carb , bypassing the air filter ,
if it wants to start but cant for long then its a carb problem
check float hight , float needle,jets and pins ,too much air getting in
find someone thats good on motorbikes , They like me know all the tricks to get things to start ,
SOURCE: My Husky pressure washer 2600 psi powered by a gcv
It sounds like the (RMW 2.2 G24) pump has gone out. Mine had this problem after about 6 hours of use. I was able to order a new pump for around $160.00, and then installed it myself. Go figure it was just out of warranty. I think my next pressure washer will be one with a professional pump as I was told the one on my husky is only rated for about 40 hours of use.
SOURCE: I have a Honda GCV
Mine is doing the same damn thing! Trying to figure out how to take off the high-pressure hose connector because I need to inspect it for clogs.
SOURCE: my honda gcv 160 pressure
Try this website at http://forums2.gardenweb.com/forums/load/lmower/msg0312290415003.html
