Dryer will not heat up
Take off the cover from the front, bottom of the dryer. You should see the burners. Take this opportunity to clean lint from the area. Start the dryer and watch this area. You should see the igniter begin to glow. If it doesn't, you could have gotten a bad replacement. If it does glow, either the gas coils are out or the temperature sensor is out. You could check them if you had an ohmmeter or replace them both as they are relatively inexpensive. I have experienced gas coils that will get so weak that even though they pass the ohm test, they still won't open with the correct voltage applied.
