Neff Appliances Series 1 T25S56N0GB Stainless Sl 70cm Gas Hob Logo
A
Anonymous Posted on Aug 01, 2014
Neff T2646 hob won't turn on at lock button - Neff Appliances Series 1 T25S56N0GB Stainless Sl 70cm Gas Hob
1helpful
Cause of Neff Induction Hob Error d4?
I can only confirm that the is no D4 Error shown anywhere. If Neff, the maker can't tell you what the error is, then surely no-one can. Very poor show. I think I would be cutting my losses and go back to a traditional cooktop from a different maker and pursue a legal case against Neff. They should change their name to 'Naff'.
NEFF appliances are among the most durable and reliable kitchen devices on the UK market. But every once in a while, a NEFF appliance will throw an error code for you to deal with.
When a fault code is displayed on your NEFF appliance, it indicates a problem, but not what that problem is or what has caused it. An appliance fault code simply detects and indicates the nature of the issue and provides the general area where investigations need to be carried out.
Bear in mind that on many occasions, your NEFF appliance will be in need of professional repair from a certified electrician to get guaranteed results.
So, if :
  • You have a problem with your NEFF appliance
  • You want to know what a specific error code means
  • You want to trace and correct faults in your NEFF appliance
Then, read on.
NEFF appliances fault codes and their importance Your NEFF appliance will indicate an error code if it has a problem. This will be shown on the digital display and will be a single letter followed by one or two numbers. You can use this appliance error code to help identify where the problem is occurring. The most common appliance fault codes are related to defective oven elements, drainage issues on washing machines, and blocked pumps in dishwashers.
A detailed look at NEFF appliance error codes
NEFF induction hob error codes The most common faults of a NEFF induction hob are:
  • The hob not starting up;
  • The hob shutting off during cooking;
  • The hob flashing after finishing cooking;
  • The hob making a noise;
  • Food isn't cooking evenly.
NEFF induction hob error codes that may help you locate the source of the problem are shown here:
  • F1 - Tnsuitable cookware is being used, or there's no cookware in the zone;
  • F2/F02/F4/F04- Tour appliance hasn't cooled down completely;
  • F8/F08 - If your hob has been working on high power for a long time, the timeout will activate;
  • E9 - There's an internal fault with your appliance electronics.
Bear in mind that most of the issues will require a certifed induction hob engineer to complete the job and fix your NEFF appliance.
Feb 03, 2022 • Neff Ovens
Glass on neff t4243 induction hob has cracked
hi,
is it possible to replace a cracked glass on my Neff induction hob?
where would I get the glass for my Neff induction hob replaced?
is it very costly?
the model number is t4483x2/09
Feb 28, 2012 • Cooktops
5helpful
3answers
When turning on my 2 year old Neff induction Hob T4543N1 it displays a full set of E errors and cuts out it does after two attempts corect itself and function perfectly
I had flashing Es every time I turned the hob on - got worse and worse until unusable. Neff help line useless - service call cost ridiculous. My problem was the capacitor on the 5 volt power supply had failed. 5 volt supply was at 3.8 volts. Replaced the capacitor and the hob's now perfect - a joy to use. Only helps if you are tech savvy and willing to open the unit, but may give you some hope or point you in the right direction.t
24helpful
2answers
Neff induction hob safety lock
safety lock is on. How can I release safety lock?
Jun 18, 2009 • Cooktops
15helpful
How do i unlock my neff hob? Red key above on/off switch wont go off! Cant use hob.
Hi I have just had the problem of accidently locking my Neff Hob.
If you hold down the L Lock button for about a minute it unlocks.
13helpful
4answers
Safety lock on Neff hob
I have a Neff T4344N0/08. I cannot stop all four hobs flashing - ie: I press the 'on' button all four flash, I then choose which one I want to use plus the number but they all keep flashing instead of stopping after the usual three or four. Please help - have I pressed something I shouldn't, perhaps a child lock?
18helpful
2answers
Neff Hob
Hold the power button for a few seconds
Neff 4 ring, ceremic top hob - how do I turn on!!
You press the "on" which is on the left. Press the picture of hob you require and press the up and down for temperature. Then put your pan on the hob and it will work. If you need to adjust the temp you need to remove the pan.
Top Neff Appliances Kitchen Ranges Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
john h
Are you a Neff Appliances Kitchen Range Expert? Answer questions, earn points and help others
