Short answer is no, if the screen is plastic and the chemical attacks the plastic. If it is too much liquid and it seeps between any layers, it could evaporate over time, but you will likely have a noticeable dry stain forever.
For you and everyone reading this, never spray or apply any liquid to any TV, monitor, laptop, or cell phone screen directly, I think it says that in the owners manual. Always apply a light amount of TV screen cleaner spray to a microfiber cloth and then lightly clean the screen. DO NOT use anything with alcohol, ammonia, glass cleaner types, baby wipes, pre-moistened wipes of any type unless it specifically states it's for LCD monitors and TV's. If you or the manufacturer apply more cleaner to the wipe or cloth than necessary, blot excess cleaner with a dry paper towel so that the liquid doesn't run or drip when applied to the screen during cleaning.
Printer's Paper Pick up Rollers get dirty or worn out with the passage of time. Hence, require cleaning or replacement if worn out. In case you find them dirty use
a soft, dry, lint free cloth to clean the rollers. Dont use chemicals
as they may damage the rubber and plastic. However, if needed, you can
use damp cloth or some cleaning liquid such as mild detergent of glass cleaner to damp the cloth.
Cleaning is simple. Vacuum the rear vents to remove any dust that has built up.
For screen and the fascia, -
1. Unplug the monitor from the power supply. 2. Fill a bowl with warm water with some washing up liquid - just as you would to clean dirty dishes. Soak a soft clean cloth in the water (Kitchen cloth - NONE ABRASIVE!! and not a sponge!), and wring the cloth out so that it is damp (not wet!) and gently wash the screen. When finished use kitchen roll to dry off the monitor. 3. Stubborn marks on the LCD, using the same damp cloth, apply a spot of neat washing up liquid to the cloth. Clean as before - DO NOT PRESS on screen. When finished, use kitchen roll as before.
Turn off the plasma display before cleaning it. Doing this is not necessary, but it's preferred, especially if you're going to use a cleaning solution spray. Since Plasma TVs use more power than and generate more heat than LCD TVs, it is best to turn it off AND allow ample time for the unit to cool to the touch before attempting to clean the screen. Failure to do this may cause your cleaning solution to evaporate before it has had enough time to remove any dust, dirt, or contaminants on your screen.[1] Some sources suggest unplugging the TV.Use a soft, lint-free cloth to remove fingerprints and smudges. Avoid wood-based products (paper towels, toilet paper, tissues) because they can scratch the screen. If stubborn dirty spots persist, go to the next step. However, be advised that some manufacturers, such as Pioneer, recommend no liquid at all on the front of their plasmas, lest it seep into the plasma display. If you must use a liquid, spray-- a minimal amount of--the cleaning solution on the soft cloth, not on the screen. If the moistened cloth is not cleaning sufficiently, you can spray additional SMALL amounts on the cloth. At no time do you want the cloth wet to the point where the solution drips or runs down the screen! See previous point for the reason why. Use either just distilled water or non-ammonia or alcohol-based window cleaner. Ammonia and alcohol are substances which will eventually cloud any plastic with microscopic "crazing," with the effect of hazing and dimming the displayed image. After wiping the screen gently, follow up with a dry cloth
Clean Your HDTV Screen Properly
Step1
Read the warning labels on all your household cleaning products. Even
glass cleaners might not be suitable for use on an HDTV screen, so
check the manufacturer's warnings before you apply anything to the
screen.
Step2
Keep chemical cleaners away from your HDTV on cleaning day. The harsh
chemicals found in most common cleaning products will actually cause
more harm than good.
Step3
Leave liquid cleaners under your sink when cleaning your HDTV screen. A
liquid cleaner, whether it be water or a chemical cleaner, will drip
down the screen and work its way into the interior of the TV, causing
damage to your HDTV. You will be able to easily recognize when this
happens, because your screen will develop smudges.
Step4
Use a cloth to clean the HDTV screen. Ideally, you should use a cloth
that is recommended for HDTV screens, computer screens and other
electronics. The word "microfiber" may be imprinted on the packaging.
Step5
Wet the microfiber cloth slightly. Just a hint of dampness is all you
need. If water runs out of the cloth, then it's too wet and will cause
smudges.
Step6
Develop a regular cleaning schedule for your HDTV screen. If you dust
the screen daily, or at least several times a week, with your
microfiber cloth, no other maintenance should be necessary. Not only
will frequent cleanings make caring for your HDTV easier, but they will
also enhance your viewing experience.
Step7
Prevent messes by asking family members and guests not to touch the
television screen. You should also try to make sure children with
sticky fingers do not come in contact with the screen.
Step8
Use a high-end cleaning product if you feel that regular dusting is not
sufficient. Top-of-the-line television cleaning products are ideal for
use on all HDTV screens, plasma screens, projectors and are safe to use
around children and animals.
It is recommended to use a simple alcohol solution to clean an LCD screen. This solution is made up of 1 part distilled water and 1 part 50% isopropyl alcohol. Be warned that isopropyl alcohol is flammable.
50% isopropyl alcohol is very common. If you find 70%, 91%, or 99% isopropyl alcohol, adjust the formula to use less alcohol and more distilled water.
By mixing these two in a bottle, you will produce a model cleaning solution. Remember not to use tap water -- only use distilled water.
Do NOT use tissues/Kleenex to wipe your screen. That is as ineffective, because they will leave little tissue partiels all over your screen . Try and find some microfibre cloth to clean your screen. Cloths that come along with prescribed glasses are usually good.
You may want to clean the rest of the actual screen before moving onto the LCD part. First dampen the cloth with the solution. You should never spray any sort of liquid directly onto the screen. Wipe the screen gently from top to bottom and wait for it to dry.
Be careful not to let the cleaning solution leak into the sides of the monitor. Also, be certain that you do not press hard on the LCD screen. You can permanently damage an LCD screen by pressing on it too hard.
DUST:
If there is just dust on your screen, there is no need to fully clean it. To remove dust all that must be done is to wipe it away with a microfiber cloth. Simply wipe your screen from end to end gently with the cloth.
I have always used regular Tide powder in mine and my kids use Tide liquid in it. You just need to use about half as much. My man is a motor head so he gets DIRTY and I have three teens so I wash a lot of very dirty clothes. My clothes get very clean and I have never purchased the "special" Detergent.
If they are grease marks you can use a warm water a soft cloth like a t-shirt and little dish washing liquid. Gentley wipe the area only stroking down or up--- NEVER SIDE TO SIDE---. Have a dry cloth ready if you drip water down the screen. Now if those are scuff marks, your done, they cannot be removed. They are like the old record albums with the grooves, once the grooves get distorted that's it. Good luck.
