Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
A
Anonymous Posted on Aug 01, 2014
My frigidaire automatic defrost upright freezer gets ice build-up at the top right at the front any suuggestions
No model number anywhere on it
Thomas Beaver
Level 3:
  • Frigidaire Master 2,119 Answers
  • Posted on Aug 01, 2014
Thomas Beaver
Frigidaire Master
Level 3:
Answers
2119
Questions
0
Helped
751136
Points
6319
This is just a general answer but it may mean that the door seal is leaking. Try running a dollar bill under the seal to see if that area is looser than the rest of the door seal.
Look inside the freezer for model number.
How to Check Freezer Door Seal DoItYourself com
5 Related Answers
Anonymous
  • 133 Answers
  • Posted on Jul 31, 2007
SOURCE: Frigidaire upright not cooling
It sound like you had a freon leak, you REALLY need to get this checked by a tech. if you are leaking freon it can be dangerous.
A
Anonymous
  • Posted on Sep 05, 2008
SOURCE: My freezer is stuck in defrost mode causing the alarm light to remain on
My freezer wouldn't run and I did find there was a reset button on the back of the freezer where the chord runs into the switch.
Anonymous
  • 2071 Answers
  • Posted on Sep 22, 2008
SOURCE: Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Jan 14, 2009
SOURCE: Ice build-up on the inside top of of freezer door
yea def , not normal, nor an acceptable amount of ice forming there( good pic). heres what i have been told to try and with good results
first make sure the door gasket is sealing all the way,(small gaps in ht emagnets at extreme corners) is common but with a little amount of "mortite"or "permagum can sometimes be insterted behind the corner of gasket to assist filling the void.
second a small amound of a white/clear silicone be applied to the outer perimtere of gasket, to minmize air movemnt from between gasket and door panel.
lastley in oyour second pic i see "frost free" written on a plastic air deflector. you can remove that with 3-4 screws on backside of it, and then reinstall with a small spacer so as the baffle now with sit with a 3/8in. gap between it and the top of the freezer liner.( a brass ferrel from the compression fitting of a plumbing fitting is just the right size)..... the theory behind this is to prevent the air from gatting "trapped" in the void created when the door closes-- air can now pass back and forth freely.
I hope this gives you some satisfaction if not I would advise another tech be sent who is willing to call for factore tech support( ths is where i got my info from)
Anonymous
  • 109 Answers
  • Posted on Aug 23, 2009
SOURCE: Freezer forming Ice on the bottom not draining water
pour some hot water in the drain if this does not work use compressed air
Testimonial: "So far that worked great, we will see if it continues to drain when the freezer is back on and does it defrost cycle."
My freezer started getting a lot of frost and ice around the top close to the henges. Now I am getting a lot of ice in the bottom of this freezer. I can break up the ice and remove it and it will be back...
there are only 2 reasons this happens but one cause (defrost element not working) 1st we check the defrost timer is working if not replace it if it is working go on to the last fault it can be - depending on the freezer it will have 1 or 2 defrost elements when one blows the ice will slowly build up if they both blow then the ice will build up within days unless you know your way around a multimeter it will be very hard to determin witch unit has blown in 70% of cases its the element but a service tech can tell you in a matter of minutes to save you time and money i would get a quote to get a tech in but now you know what to look for
best of luck to you
please remember to rate this repair .thank you
Upright freezer,automatic defrost.
drain is clogged remove ice with hair drier and hot water
May 09, 2010 • Freezers
4helpful
2answers
My upright freezer won't self defrost. Frost builds up right awa
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
I have a upright freezer model number is ffu11fkodwo and the name is frigidaire commercial.The problem is that ice is building up inside the freezer.I know its an automatic defrost cause I made sure before...
It sounds like one of the defrost components is bad. Could be a defrost timer, defrost heater or a defrost thermostat. If you are at all handy you can change these parts yourself.
Aug 28, 2009 • Freezers
1helpful
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
1helpful
I have a 4yr old 13.7 cubic upright frigidare freezer. Running all the time, I defrosted it recently (only minimal frost/ice on base behind basket) after noting top shelf warmer than others and food...
Hi, Put a thermometer in the freezer and see if it gets down to 0 to 5 above zero. If it is not getting that cold, something is wrong. If you had frost building up behind the rear panel, there is a defrost problem.
Please let me know the temperature and I can assist you further.
Vic
1helpful
Ice build-up
Hope this may help;
Regards,
VOTIT
66helpful
7answers
Ice build up in my frost free upright freezer
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through
and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
Top Frigidaire Freezers Experts
ZJ Limited
ZJ Limited
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
