When plugged in the red light on the television does not come on and the television does not work. Other appliances work in the same socket. I have checked the fuse and it is okay.
SOURCE: viera link pop up problem...ANNOYING
You need to (either or both) change from Shop setting to Home, and turn off Viera Link demo.
Go into the menu, choose set up and re set to shipping settings.
SOURCE: Panasonic Viera TX-L32X20B no channel found
the problem looks like bad main board , try to do the auto program , and see if it works , if dont work main signal board need to be replace
SOURCE: Panasonic Viera 65 inch tv shut off, will not turn back on. Red light blinks 7 times.
Power supply or related to it.
