Hey my Garmin will not show the correct time to destination even thou I have it in truck mode it set the time as if I could go at the speed limit for cars. can anyone help :) ?
SOURCE: i want to change the little car on the map to a truck
Don't know if they have exactly what you want but here are some trucks in the lineup:
http://www8.garmin.com/vehicles/bundles/allvehicles.html
SOURCE: I want my Garmin to take me on a different route
On most Garmins there's a button marked "detour". On the touch screen versions it's an on-screen button rather than a physical button.
SOURCE: My Garmin StreetPilot 2730 won't hold its settings.
Do a hard reset.
Turn the unit off, then hold down
the menu and map buttons, simultaneously, then turn the unit back on
and continue to hold down the buttons down for at least five more
seconds, then the unit will power up. At that point it's like the unit
is being used for the first time and you will have to reset everything.
You will lose your XM presets, but the MP3's were still there.
Also after if this does not work, plug in your
garmin and mount it, mac or pc whatever, then go in your garmin file
erase all maps should be gmapsupp.img or gmapprom.img. Reload your maps
from mapinstall.
SOURCE: after update on my garmin 1300, i lost time of
there is a screen that give you the choice of which detail is shown in the unit, touch the left corner of screen the the map is displayed that should bring up the options, if not is try reset by holding down finger on bottom right hand corner of screen before you power up, and go to www.garmin.com for software update
