Canon iR 2016i Black and White Copier Logo
A
Anonymous Posted on Aug 01, 2014
What is the problem when my canon ir-2016 says out of tonner
SURAMUL HAQUE
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Sep 01, 2014
SURAMUL HAQUE
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1210
Points
Magnet roller poor contact on roller bush connector... other wise roller blade ya roller stick clean properly Nd cheek board connector.. otherwise the magnet roller is damaged... clean the full toner unit...
Nik Shamsul Nik Mohammad
Level 2:
Sniper:
  • Expert 77 Answers
  • Posted on Aug 01, 2014
Expert
Level 2:
Sniper:
Answers
77
Questions
0
Helped
38477
Points
158
You need to replace new toner
  • techstar
    techstar Feb 28, 2019
    jolo ko.
5 Related Answers
Anonymous
  • Posted on Apr 20, 2009
SOURCE: canon ir 2016 cannot/wont connect to computer via usb
I have a machine it write DOWNLOAD STANDBY.Hw may i do it.
Anonymous
  • 117 Answers
  • Posted on May 07, 2009
SOURCE: canon ir 2016 problem E019
Product : imageRUNNER 2200/2800/3300(i)/2220N(i)/3320N(i) Title : E019
Error :
E019-0000 is displayed on the control panel.
Workaround :
This error code is the indication of the waste toner container being full or a problem with the detection mechanism. Actions to be taken are:1. Turn the machine off and check the waste toner container. If the container is full, empty the container. Clean the inside and outside of the container's neck with alcohol. Be sure that the neck is clear and not soiled with toner before placing it back into the machine. Turn the machine on and check to see if the code went away.
2. If the container isempty and the code is still displayed, check the neck of the container. Turn the machine off and check the container,if the neck is dirty, clean the inside and outside with alcohol before placing it back into the machine. Turn the machine on and check to see if the code went away.
3. If the machine still displays the code after the bottle is emptied and the neck clean; check the sensor, the sensor connections to and from the DC controller PCB for continuity, and the proper positioning of the sensor. Replace the sensor if it is damaged or excessively soiled with toner.
Anonymous
  • 117 Answers
SOURCE: canon iR 2016 copier problem E019
Error :
Workaround :
Anonymous
  • 1219 Answers
  • Posted on Jul 16, 2010
SOURCE: where can i get the codes canon ir 2016 series.
Hi, here you go:
E000 0000 Fixing temperature abnormal rise
E001 0000 Fixing unit temperature rise detection (by main thermistor)
0001 Fixing unit temperature rise detection (by sub thermistor)
E002 0000 Fixing unit temperature insufficient rise
E003 0000 Low fixing temperature detection after standby (by main thermistor)
0001 Low fixing temperature detection after standby (by sub thermistor)
E007 0000 Fixing film rotation error
E010 0000 Main motor rotation error
E019 0001 Waste toner full detection
0002 Waster toner full detection sensor failure
E052 0000 Duplex unit connection error
E100 0000 BD cycle out of range
E197 0000 Erroneous communication with printer engine
E500 0001 Finisher communication error
E520 0000 Offset error
E531 0000 Stapling error
E540
0001 Paper surface not detected (standard tray)
0002 Not moved within the specified time (standard tray)
0003 Sensor not reached within 3 seconds (standard tray)
0005 Encoder clock failure (standard tray)
E542
0001 Paper surface not detected (optional tray)
0002 Not moved within the specified time (optional tray)
0003 Sensor not reached within 3 seconds (optional tray)
0005 Encoder clock failure (optional tray)
E575 0000 Stack delivery error
E584 0000 Shutter failure
E716 0000 Erroneous communication with optional cassette
E719 0000 Erroneous communication with card reader (serial communication)
0002 Erroneous communication with coin vender (serial communication)
E733 0000 Erroneous communication between controller and printer
E736 0000 CCU communication error
E739 0000 Erroneous communication between controller and network board
E744
0001 Language file/boot ROM/USB memory error
0002
0003
0004
E805 0000 Fan failure
E808 0000 Fixing drive circuit failure
Anonymous
  • 92 Answers
  • Posted on May 23, 2011
SOURCE: my photocopy, the iR 2016
hello.
you could try to remove the developer (is where you put the bottle of toner) and clean the toner that is in the machine and the contacts.
3answers
What is the reason for blank copy in ir3300 copier
Check the fixin unit,lamps,thermistor,thermal fuse
2answers
Canon iR-2016 System erro E007
The fusing unit needs to be replaced or repaired. Contact your dealer or service person
My photocopy, the iR 2016 does not read the amount of tonner. It sends a messege that the tonner is out while is half full.
hello.
2helpful
2answers
I HAVE A NEW CANON IR 2016 COPIER/PRINTER.
I have canon ir 2016 printer.How I install it .
I replaced the black tonner on my Canon ir 3320n & this eror sho
try to set the toner a few times more, this error code is developer trouble.So it could be that toner isnt recognized, not properly inserted, or you have some tape leftovers on toner, or you have broken developer unit, or ...
11helpful
2answers
Canon ir 2016 cannot/wont connect to computer via usb
10helpful
2answers
Canon ir 2016 copier on display says ( Download Standby) thanks
We have a Canon IR 2016 J and in a beginning in the dispaly appears the message "Download Stanby" then after we replaced the PCB board appeared the message "System Error E354" what should we do to solve this problem, and if it is possible to send us the Service Manual with error codes for Canon IR 2016
63helpful
6answers
hi how do solve this problem system error E007
5helpful
2answers
Troubleshooting, Error Codes for canon ir 2016.
I have problam Canon IR 2016 error message SYSTEM ERROR E 007
old marine
old marine
ZJ Limited
ZJ Limited
