Nikon D40 Digital Camera Logo
Posted on Jun 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nikon D40 flash firing when down
I've got an intermittent problem with my D40. Sometimes when I am shooting in programmed auto mode with the built-in flash down, the flash has fired whilst down. This has caused the plastic in the flash casing to melt a little and causes a burning smell when it happens. It doesn't seem to have affected the operation of the camera or flash, but obviously it's not ideal and I wondered if anyone knows how to fix it.
  • annewitton Jun 30, 2009
    Thanks for the workaround. That's what I have been doing, but I wondered if there's a way to actually fix the problem (or is it one for the camera repair shop?). Has anyone else had this problem?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 04, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
197
Points
When the flash is pop up then it's switch turn to on which I think is remain on in off position too .I have done many in past.
Any of you can contact
[email protected]
Anonymous
Level 2:
  • Expert 375 Answers
  • Posted on Jun 30, 2009
Anonymous
Expert
Level 2:
Answers
375
Questions
0
Helped
156459
Points
973
Turn off the flash manually (top left button on the side of the camera body above the lens) or use the 'No Flash' Program Dial option - one click back from the green AUTO selector on your dial - the one with the lightning bolt inside a circle.
D40 does not shoot on auto mode
on the side of the lens check to be sure it is set to auto and not manual.
1helpful
2answers
Flash not popping up - did i push something?
Make sure you're not shooting on no-flash auto mode. Also, in P, A, and M modes you'll have to press the flash button on the side of the camera by the lens mount in order for the flash to pop up. If it's not popping on regular auto mode, make sure you don't have it disabled in the menu.
1helpful
Nikon d40 built in flash not firing but it popped up
there is a sensor in there that tells the camera the flash is up you need to take it to a repair shop its not a at home thing
Nikon D40 built-in flash...
Hi and thanks for coming to FixYa.
You can set the parameters for the manual flash in the Custom Settings Menu. Select Full to set the manual flash adjustments.
Hope this helps. Let me know if you have any questions in a comment.
Rob
Nikon d40 all pictures are coming out red
What white balance mode are you using? Try changing it to Auto. Did you ever try to clean the sensor?
18helpful
4answers
How do I get my nikon d40 to take Black white pictures?
You CAN!!! shoot in b/w with a d40, the only thing is you can't shoot in auto mode it has to be manual , aperture priority, or shutter prioirity. Go into menu - shooting mode - optimize image. you'll find it in there.
The built-in flash on my nikon d70s does not always fire. sometimes this goes on for quite a few frames before it functions again. and often when it does decide to "wake up" it fires way too hot...
Forced flash will not work in auto. If you are not using 'P' mode you should. In 'P' mode it will flash everytime.
That said, the many flashes does not sound right. I would call Nikon's tech help line at 1-800-nikonux.
Flash
If you shoot in Auto mode, the camera will not allow you to turn off the flash when it senses that it is needed.
To use the camer without the flash, change the mode to Program ("P"). Once it's in P mode, the flash will not fire as long as it's in the down position. When you want to use the flash, press the speedlight release button (the one with the little lightning bolt near the mode select dial).
3answers
Dark wiew
is it set to auto? if not i suggest you check the aperture and shutter speed setting :)
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
