Blackberry 9720 Smartphone - Wireless LAN - 3G - Bar - Black SIM - OS 7.1 Tavor806 MHz - 512 MB - 7.1 cm 2.8" - LCD 480 x 360 - Touchscreen - 5 Megapixel - CameraQuad Band GPS Reciever - Bluetooth - USB - 7 Hour Talk Time Logo
A
Anonymous Posted on Aug 01, 2014
Bb battery will not charge
My phone doesnt charge even if i change chargers
Scott Goeken
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Aug 01, 2014
Scott Goeken
Contributor
Level 1:
New Friend:
Answers
13
Questions
Helped
1257
Points
34
Odds are it's either is a loose USB port (It happens quite a bit) or the battery has gone bad, Either way I would check with the carrier as it is a new enough phone that it could be a issue covered by your warranty so the phone can be repaired or replaced ( my experience with Blackberry's are the ones I've had trouble with were replaced in a short period of time, but that could be just luck on my part, although no one I know who has dealt with them have had any complaints)
byfield_mich
Level 1:
New Friend:
  • Contributor 30 Answers
byfield_mich
Contributor
Level 1:
New Friend:
Answers
30
Questions
0
Helped
3269
Points
86
Ok try plugging in a fresh charger and lift up on charging port into your phone slowely wiggle it around on ur phone untill u see it charging
Why when i charge my bb the touc doesnt work|?Wht can i do?/
I changed the battery and the wall charger , found out the earlier charger pin was faulty causing the screen to hang while trying to use during charging
tip
My AT&T Blackberry Curve does not charge anymore, is it the battery or the...
Hi.
Here a series of useful answers to common questions asked when an At&T Blackberry is not charging anymore.
1. My Blackberry is not charging anymore. Is it the battery or the charger?
Possible reasons are faulty battery, defective charger, bad contact on phone socket to charger.
When it is a charger problem, or a bad contact to charger, the phone will not detect that the battery charger is connected.
When the problem is the battery, usually you can see the charger beingdetected, and the charging line progressing, but the battery nevercharges.
The charger can also be tested using a Voltmeter. If the charge is in good working order, the Voltmeter will read a value within half volt from charger specifications.
2. Do batteries actually lose ability to work?
Yes they do, and the fault is not unusual.
3. How much will a new battery cost?
Most ordinary Li-Ion batteries for BB are sold at less than US$10. You can see a choice of sellers here: Blackberry Curve Battery
Ensure that the battery is compatible with your Blackberry model.
4. How much will a new charger cost?
The charger is also commonly sold at less than ten US$. You can see a choice of sellers here: AT&T Blackberry Curve's charger.
Ensure that the charger is compatible with your Blackberry model.
5. Will AT&T service the phone?
They will do, providing that the phone is still under warranty. Newwireless devices like your BB carry a one-year warranty from date ofpurchase. Refurbished devices carry a ninety-day warranty from the dateof purchase. If the phone had been purchased in US, to make a warranty claim after the first 30 days from purchase, you can call At&T at1-800-801-1101.
If the phone warranty has expired, a good choice could be going to anAt&T licensed phone shop, and asking to test battery and chargeron the bench before buying a replacement battery.
My bb curve wont charge ive tryed a new battery and charger the red light doesnt even turn on idk wat to do i just woke up and it was off plzzz help
Hi
Try cleaning your phone charger port wit brush.do it gently.
check for the charger port is loose with the board or not.
if its loose .you have to take it to the technician to fix it.
If this problem occured while your phone is being connected with charger then this might be a problem with the mother board.some times it happen becz of voltage fluctuation.
Thank you.
Sep 15, 2011 • Cell Phones
2helpful
My BB 8520 battery got drained last nite and i start charging it in the morning, only red lighhts flashing on the led but its not opening at all.i charge it for 4 hours still not opening.
The battery cell is very weak. Using a charger won't wake it up. To wake up the battery cell, you need to charge the battery with a desktop charger. After that, you can continue charging with your BB charger.
I hope you understand the message I am try to pass above.
I summary, the battery cell needs to be boosted to wake up the battery cell. Your BB charger cannot do that.
Good luck.
2helpful
2answers
Got a new blackberry pearl will not charge is it
Try a different charger (like your car charger instead of your home charger) - make sure while it's plugged in - the display shows that the charger is charging it, blinking - or bars going up or down, or a thunderbolt on the display screen next to the battery power symbol etc
Once you know your charger is working, its probably easiest to find someone else with a BB and ask them if you can trade them batteries for a day to see if it's a bad battery. ( You can usually buy a battery for $5 on ebay, or up to $20 in a cell phone store)
All in all, trade someone for their battery, or their charger - if you dont wanna buy one at first. See if the problem follows your old battery etc..
And if neither solve your problem then its the BB itself. I have called in to the cell company before and let them know we have a BB that will not hold a charge no matter what battery or charger I use... and they usually replace it under warranty as long as its less than 12 months old, and the white squares in the battery compartment are still white.
Charging alien battery?
if you had given for servicing anywhere in any other shops other than the authorized service centres, they might have changed the batteyr. try top get that problem solved.
2answers
My BB 8320 will not power up
try turning it on with the battery removed while it is connected to the charger.
if it turns on fine then, it's a battery issue. if it still doesn't come on, i would recommend reinstalling the device software with the desktop manager software. both are available on blackberry.com
1helpful
Blackberry 8830 world edition wont come on at all.
Well leave it plugged in over night - BB's run power even when they are powered off. You'll need a full day of charging if it's been off for awhile.
Mar 12, 2009 • Cell Phones
3helpful
3answers
LG shine wont charge
yeh same problem with me, take the battery out, put it back in, then stick the charger in and it will work
Top Blackberry Cell Phones Experts
NOEL
NOEL
john h
Are you a Blackberry Cell Phone Expert? Answer questions, earn points and help others
