Sewing Machines Logo
A
Anonymous Posted on Aug 01, 2014
Huskeystar219 how to thread the sewing machine
radcal
Level 2:
Novelist:
  • Expert 196 Answers
  • Posted on Oct 26, 2014
radcal
Expert
Level 2:
Novelist:
Answers
196
Questions
Helped
95980
Points
386
The manual is a free download from Husqvarna Viking. Follow this link to the page and scroll down to the "Download Manual" button:
http://new.husqvarnaviking.com/support/HUSKYSTAR-219
Debbi's Sewing Machine Repair
Level 3:
  • Sewing Machines Master 7,365 Answers
  • Posted on Aug 01, 2014
Level 3:
Answers
7365
Questions
Helped
1742258
Points
19451
Here is a link for a manual or you can check youtube for a video
Viking Huskystar 219 224 User Guide
1 Related Answer
Anonymous
  • Posted on May 22, 2010
SOURCE: Sew Cute SC20 Mechanical Sewing Machine: how to thread sew cute machine ...
Place the origin bobbin thread so the thread is coming up (clockwise) extend to the thread tention, to the top thread holder, then down through the arm and then through the bottom thread holder, through the square thread guide above the needle, then through the needle, front to back. Check out a picture on ebay or amazon. That could help you visualize it.
If you are having trouble with the thread breaking, try changing the thread on the bobbins. The thread that comes with the machine is poor quality and jams & breaks. If you still have trouble, and might suspect the needle is dull or bent. Change it, it makes a difference. I had the thread problem with the machine right out of the box. Changed it and it works great!
2answers
Breaking thread on Bernette sewing machine model 200B
Is there too much drag on the thread?
Please click the Comment link to respond.
How to thread a bobber model SE 200JjoAnnSewEssential sewing Machine
The thread will now go downward on the left side of the take-up lever.
  1. Locate and thread any thread guides, leading down to the sewing machine needle.
  2. Thread the sewing machine needle. Hold the thread with your left hand and turn the hand wheel.
  3. Watch for any thread to flap around.
Step-by-Step Guide to Threading a Sewing Machine - The Spruce.
or go to this link. How to thread bobbin Essential sewing Machine Google Search
After threading the machine, start to sew and the thread breaks it seems that it gets caught in step 4 in Threading The Machine in the manual.
Not knowing the make & model of the machine limits out ability to help. What is Step 4? When threading the top thread, ALWAYS RAISE the presser foot. Verify that the thread path is correct--mis-threading is a frequent cause of broken thread.
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Is My Thread Breaking How to Avoid Thread Breakage at Your Sewing...
I need a picture to thread my sawing machine
What machine?
https://www.bing.com/images/search?q=thread+sewing+machine+diagram&qpvt=thread+sewing+machine+diagram&qpvt=thread+sewing+machine+diagram&qpvt=thread+sewing+machine+diagram&FORM=IGRE
Why the thread cracked with when i sticked with the machine
Thread breakage could occur for several reasons.
First, try a brand new needle.
Second, use only good quality thread--NOT old thread or bargain bin varieties.
Third, when threading the upper thread, be sure to ALWAYS RAISE the presser foot throughout the threading process.
Verify that the thread path is correct (consult the owner's manual). Incorrect threading will usually break the thread.
Check that the upper thread tension is set at the midway point between the high & low numbers.
Why Does My Top Thread Keep Breaking Sewing Machine
NMSU Checklist of Common Machine Troubles
Why Does My Thread Keep Breaking While Sew
1helpful
3answers
Threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
