Try doing this:
Self-check indication only:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [OK] button on the remote control
for more than 3 seconds.
Self-check indication and forced to factory shipment setting:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote
control for more than 3 seconds.
9.1.2. Exit
Disconnect the AC cord from wall outlet.
This is straight out of the service manual.
Regards,
Joseph Van Buren
SOURCE: no picture just av1
If the cat sat on the remote, it is likely it changed the tv to AV1. Just find the AV button on the remote and press it again and again. It should cycle through the different AV channels your TV has - my TV has 6 AVs, 2 HDMI and a PC channel so if yours is anything like mine, you may need to press several time to get back to your Sky/freesat/virgin box. Alternatively, some HDMI connected kit just needs turning off and on. That then sends a signal to the TV which changes the TV automatically. For example, my Blu-ray player does that.
Experience - I have a cat that sits on my remote and does the same thing!!
