Question about Belkin Wireless (F5D7130) 802.11g/b Wireless Access Point
Belkin f5d7130 cant connect
Ive set up tis router as instructed in the manual but i cant connect to the device wirelessly to do any sort of setup.
the lights are as follows power is green, wlan is green but flashing and the lan is flashing orange
any ideas how to fix this issue ive tried to plug it direct in to the switch that controls our company internet and to a hub connected to our network but still no change
6ya staff
SOURCE:
Anonymous
SOURCE: Wont connect to the internet
Try this, assuming you're using Internet Explorer: Go to Tools > Internet Options and select the Connections tab. Does it show your old dial-up connection in the list? If so highlight it and click on REMOVE. Close IE and re-open it. It should now use the Belkin LAN connection.
Posted on Aug 18, 2007
Anonymous
  • 51 Answers
SOURCE: Belkin USB Plus Hub - F5U304
PLEASE INSTALL THE DRIVER CD IN YOUR PC AND RECONNECT IT WILL DEFENITELY SHOW...
THANK YOU...
Posted on Jan 05, 2008
stif_NEC
Serwen Bagadiong
  • 441 Answers
SOURCE: http://192.168.1.1 is not working anymore? i cant set up the router
Try resetting the router, press the reset button at the back for 10 seconds, after that release the reset button and then unplug the power of the router, then wait for 10 seconds and then turn it back on.
After that try accessing the IP of the router 192.168.1.1 (if this did not work try 192.168.0.1,this varies on the model number of the router). Or follow the same steps you have done previously.
Posted on Aug 16, 2008
Anonymous
  • 18 Answers
SOURCE: connect belkin f5d7130 to homehub 1.5
You need to connect all pc's and homehub to a switch so they can talk to one another. Then use the AP as a wireless access point to connect all wireless laptops, and connect the AP to the switch with ethernet cable, and you have a network. Just make sure that only your HH or AP supplies IP addresses or they will clash.
Posted on Oct 19, 2009
A Soveral
  • 566 Answers
SOURCE: does anyone know where i can get the setup
You can download the manual and quick instalation guide for the F5D7130 Wireless Network Access Point
from Belkin. No software is needed nor is supplied with the access point.
If you bought the access point bundled with the network card F5D7010, then the disk that came with it would have the drivers for the card. You can get them from Belkin also. Click here
Posted on Dec 19, 2009
Cannot set up belkin HDTV adapter F7D4555v1
You can also try to connect this device using a wired connection to your computer or laptop Running Windows 7 or Windows 8. The first thing to do, is make sure that you press the little reset button on the device so that the device memory is cleared. Then all you have to do is open up Google browser or Internet Explorer and type in 192.168.2.1 and hit enter, and that will bring you to the Belkin Setup Menu. From here you can add this device to any home or office network just follow the on-screen step-by-step instructions
Dec 27, 2012 | Belkin Computers & Internet
I can not get it to work at all. Is there a CD I need to get this set up? I have a Linksys wireless G router and the Belkin F5D7130 plugged in to it. But I have no range.
You don't need a CD - there is a web interface. First, download the user manual here.
I suspect your problem is the Linksys/Belkin combination. Linksys by default uses a subnet of 192.168.1.xxx while Belkin uses 192.168.2.xxx. With a subnet mask of 255.255.255.0 (the default for both), no communication would be possible between these two subnets. The "255" in each of those first three octets means they must match exactly.
Either move the Linksys to 192.168.2.xxx or the Belkin to 192.168.1.xxx (and keep the same subnet mask) OR you can change the subnet mask to a broader one (255.255.254.0) that allows the two different subnets to talk to each other. This subnet mask would have to be applied to both devices.
According to the manual, the default address of the Belkin is 192.168.2.254, which leads to your next problem - your PC probably can't connect to the Belkin device. Assuming your PC is configured for the Linksys subnet, the easiest way to communicate with the Belkin is to use a network cable directly linking your PC to the Belkin (may need to be a crossover cable) and manually set your PC's IP address to one in the same subnet as the Belkin, like for example 192.168.2.200 with a subnet mask of 255.255.255.0. Then you can open your web browser and point it to the Belkin default address, as outlined in the manual, and make whatever changes are required.
Feb 21, 2011 | Belkin F5D7130 And F5D7010 (Bundle)...
Does anyone know where i can get the setup software for my belkin f5d7130 access point?
Dec 19, 2009 | Belkin F5D7130 And F5D7010 (Bundle)...
Connect belkin f5d7130 to homehub 1.5
Oct 19, 2009 | Belkin Wireless (F5D7130) 802.11g/b...
We formerly used a linskys router, How can we
if you have not changed any settings from belkin router, access the wireless configuration on your windows machine and search for the belkin ssid then hit on connect
Sep 23, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Connection
The setup page to configure Belkin routers is at http://192.168.2.1
If you have changed it, reset the modem to factory defaults by using a paper clip in the small reset hole.
Jul 04, 2008 | Belkin Wireless G (F5D7130) (F5D7130FR)...
My belkin router wont work :(
If you access your router, look at the wireless settings, you may need to change a setting to allow b + g connections, your laptop may have a 'b' adapter.
Mar 09, 2008 | Belkin (F5D72304F5D7000) Router
Xbox 360 help
All devices on your network should be assigned an IP address. They need it to be identified on the network. You can try rebooting your router. The wireless on belkin routers can be a bit temperamental. Then try the 360 setup. If you are still coming up blanks, then check your router's DHCP server setting. Make sure that it is turned on. (It is the function that assigns the IP address.) My lat suggestion is to manually assign an address to the 360. Try this only if you are familiar with how IP addresses work. Hope this helps....
Aug 27, 2007 | Belkin Wireless (F5D7130) 802.11g/b...
Networking
You actually have a couple of issues here. Fix these in this order. 1.) Login to router and turn off wireless (if you're not wanting to use wireless) 2.) Connect the ADSL modem CAT5 port to the WAN port of the Belkin router. 3.) Login to router and turn on NAT and make sure DHCP is enabled. 4.) On your Windows machine turn on DHCP under the network settings. This should allow your connection to be setup automatically and stop wireless access on the Belkin router. Let me know if you need more help. JC
Jun 24, 2006 | Belkin Wireless (F5D7130) 802.11g/b...
Belkin Wireless (F5D7130) 802.11g/b Wireless Access Point Logo
196 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
