How can I get my battery charged out of my phone as I have upgraded to a new phone but need to charge my old battery as need to get my contacts off of it but the battery is ok and charger ok it's the charging socket on phone that's the problem
Probably you will have to buy an external battery charger that will charge the type of battery the HTC Wildfire is using. But if you upgraded to another HTC phone, maybe the new one is using the same battery as the Wildfire and then you can charge the old battery in the new phone and then use it in the old phone to transfer your contacts to the new phone.
SOURCE: BATTERY UNABLE TO CHARGE, ALTHOUGH PHONE WORKS
Well, the white to pink dot is a sign of water in the phone. It is a moisture indicator and the first thing the repair fols look for so they can deny any claims.
They second thing is you can get an external battery charger for the razor. They run about 5 dollars and allow you to charge the battery seperate from the phone.
Razr V3 external battery charger
SOURCE: MY MOBILE PHONE CHARGING SOCKET HAS SNAPPED
You have 3 options when the charge port breaks.
1. get it repaired, warrant if possible
2. Get a new one
3. Get an external battery charger and charge battery separate from phone. Another battery and charger will set you back about 10 dollars on ebay.
For more information and links to the parts check the following link below.
Fix for Broken Charge port on Samsung SGH-D900
SOURCE: HTC battery wont charge
I have the same problem. Try this: 1) remove the battery, 2) plug the phone in the wall, 3) put the battery in. I tried that sequence of actions a few times and finally after a few tries it is recharging. (I read that tip on some other Internet thread, to put the battery in while it is plugged in).
