Question about Heartland Refrigerators
How long should a GH36 heartland refrigerator run?
It runs all day long..
E7 message
A/C Blowing circuit breaker and giving a error code E7 - Heartland ...
https://www.heartlandowners.org/.../24381-A-C-Blowing-circuit-breaker...
May 21, 2011 - 10 posts - ‎4 authors
Has anyone have any idea what could cause this issue? It is a Dometic rear AC with HP and will not cool at all. The fan runs but no cooling at ... Dometic Refrigerator - Error code E-3 - On the road, help ...
Jun 6, 2015
Dometic CCC 2 Error Code E7
Aug 9, 2014
Dometic A/C won't turn on with remote or from unit
Aug 30, 2012
More results from www.heartlandowners.org
Dec 02, 2015 | Heating & Cooling
The temperature on my Heartland refrigerator fluctuate between 34 deg and 50 deg, is this normal?
How long does this temperature issue last? When you notice this issue how long does this sit at the hire temp, 1 hour? I am trying to understand why Heartland/Marvel would ask you to turn it off. Please let me know. Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 01, 2014 | Heartland Refrigerators
Glass lid for skillet exploded and shattered into small pieces; how can I get a replacement?
Indeed there is a recourse. Contact the Better Business Bureau with a cc. to Heartland and you just may see some very speedy action on your behalf. It is even possible that the BBB itself sends a cc to companies they receive complaints about.
Dec 30, 2013 | SAVOUREUX PRO LINE 12 Piece Stainless...
Heartland paragon schematic
page 51
http://www.guaranteedparts.com/picture_library/Heartland/Ranges/Paragon/Paragon%20duel%20fuel%20range-HL-P44.pdf
Jul 18, 2012 | Heartland Paragon HL-P44 Kitchen Range
Won't cool. Lights come on when door is open. Power is ok. Compressor doesn't seem to be coming on.
Check to see if there is power getting to the compressor. If there is you probably just need to replace the overload relay that attaches to the compressor. There is the possibility you will need a new compressor, but usually you will hear something. There are 3 terminals on the compressor, one by itself, and two side by side. The one by itself is common, the other two are start and run. With a meter check common to start, then run. Both should be below 10 ohms and the start terminal has slightly higher resistance than the run terminal.
If you dont have power, you will have to trace power back to the control board, or the thermostat. I can give you more detailed instructions if you give me the full model number.
Hope this helps.
Jan 30, 2011 | Heartland 3060 Bottom Freezer Refrigerator
I have the Legacy model 3530-3630 gas/electric stove.....my problem is this: for the past few days there is what sounds like a fan running in the oven. This runs constantly whether I am using the oven...
This is the convection fan. My hearland range does this too, after power loss in the house. I cancel it by starting and then stopping convection mode. ie. hit convection (fan icon) start (running man) and then cancel (X).
Dec 27, 2010 | Heartland 3530 Dual Fuel (Electric and...
I have 36'' Heartland refrige Model #3100. Every year or so refrige section stops cooling. I unplug for about 1 day after transfering food plug it back in and its fine. Any help would be greatly...
your frezer unit need to be check what you actualy do is defrost the unit every year :) but the problem is in your freezer unit that might be the heater unit / your fan.
Dec 30, 2009 | Refrigerators
The cooling fan stays engaged after a cleaning cycle. How can it be turned off as it has been running for 2 days now.
The problem is the oven door latch. Open the oven door and you'll see the latch on the left front. When it's to the right, the readout will read "SC" for self cleaning. When pushed back left, the fan stops. Apparently the latch does not return to the off position after SC. Snap it back a few times and it may stay off. If not, you'll have to fix it.
Dec 06, 2009 | Heartland 3525SS Dual Fuel (Electric and...
I received a electric car jack from Heartland of America and had to send it back to them because the plug didn´t work for my 2008'Toyota Highlander and the 1999 Ford Taurus. they replaced the jack and...
> I contacted you (?) by phone and was assured that you (?)would send me another unit within 3-days.
I don't think you contacted anyone on this site.
I'm afraid Fixya is not going to be much help; your problem is with Heartland.
I have dealt with them often over the years and have not personally had a problem with them.
Sep 03, 2008 | Toyota Highlander Cars & Trucks
Refrigerators Logo
37 people viewed this question
Top Heartland Refrigerators Experts
Marvin
Marvin
Gil Shultz
Are you a Heartland Refrigerator Expert? Answer questions, earn points and help others
