Water blowing out of air vents for motor
Have you over filled it and tipped the karcher to one side that sometimes makes warter blow out the vents give it a good shake on its side then try again.
Mine does the same even with a small amount of water in bottle. Seems like a badly designed seal between bottle tube and head of machine. Blows water out of vents when machine is in various positions.
Mine does the same almost as soon as i start to use it!!
Yep, mine did the same and now out of guarantee. It's a bad design alright, where waste water enters the wrong canal as this is not sufficiently sealed. I have made myself a little hood with elastic on one end from a thick old towel on one end and I pull this over the louvre vents to catch any spray or drip. Guess you could easily use a white towling sock, which does the same thing. Change the water frequently. This works for me.
