Press [PGRM] [|=>][NEW][1:Create New][ENTER]
At the prompt NAME=, Type the name of the program.
Use the catalog [2nd][CATALOG] to enter the commands
Input, Lbl, nDeriv(, Disp, Pause, If, abs(, Stop, and
Goto.
In the catalog, the entry mode is ALPHA
- The fisrt two lines of the second screen are not to be entered. (It is an overlap). I had to scroll down to get to the bottom of the program editor screen.
- Before you can use it to solve for the zeros of a function, you must define it in the [Y=] editor.
- The symbol Y1 in the program listing can be entered by pressing [Vars][|=>Y-VARS][1:Function][1:Y1].
- When finished entering the program press [2nd][QUIT] to exit the editor.
To run it, press [PGRM]. Under the menu [EXEC] you see a list of the available programs. Select the one you want and press [ENTER]
During the run, the program finds an iterate and waits (Pause) for you to press [ENTER]. You must keep pressing [ENTER] after each iteration, until it returns Done.
Hope it helps.
Thank you for using FixYa.
Do not forget to rate the solution.
