Question about LG 37LG30 37 in. LCD HDTV
My tv has no brightness
DON'T KNOW TO OPERATE REMOTE CONTROL
    Top Expert:
  • LG Master
  • 76,140 Answers
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Posted on Aug 01, 2014
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 88 Answers
SOURCE: LGE LCD Remote Control no longer works
Bad filters on the main board or a bad AUX REMOTE jack on the back of the unit (also part of the main board) re the cause of this problem.
Try plugging in any jack that will fit into the AUX REMOTE jack on the back and then pulling it back out. This may fix the problem or remove any dust that may have collected in the jack. If this jack has something plugged into it (or goes bad) the TV will no longer have remote control operation (because it thinks an external remote box is being used). If this does not work then the main board will need replaced.
Note, many repair techs will think the IR board is bad (the Infra-Red Receiver board) at the front of the TV, but this is usually not the case with this model.
Hope this helps, please rate my solution.
Posted on Jan 11, 2009
SOURCE: My child lost the remote control and I don't know
HI
What a shame, look for a button/knob/touchpad on the front of the television set.
There should be buttons for all the major functions of the TV.
Down to the right.
I hope you will find your remote control.
All the best
kolbrun
Posted on Feb 20, 2012
How to operate with remote control
VCR Remote Control Buying Guide ' eBay
www.ebay.com > ... > TV, Video & Audio Accessories > Remote Controls
Finding a suitable VCR remote control to operate a combo unit involves finding a remote that supports the functions of each component of the unit. The key to ...
REMOTE CONTROL MANUAL Synergy V - RCN
help.rcn.com/pf/12/webfiles/files/ONNET6907/remotes/RC.../index.htm
Jump to Operating In VCR mode - Your remote control is designed to operate many functions of your VCR. To select your remote's VCR mode:.
Program and Operate Your Cox Remote Control
www.cox.com/business/support/.../article.cox?...
Cox CommunicationsApr 28, 2015 - ... on how to operate and program the buttons on your remote control, select from ... Index of Remote Controls ... Program TV, DVD, VCR, Stereo.
VCR remote control codes ' FiOS TV ' Residential Support ...
Jan 14, 2016 | Televison & Video
Tip
Why Am I Unable To Program The RCA Remote Control To Operate My Components
Why am I unable to program the RCA remote control to operate a component? Why am I unable to program the RCA remote control to operate a component? If you are unable to program the remote control to operate a component, review the following information:
Compatibility
If none of the programming procedures work, the universal remote control may not be compatible with your components, based on the type of infrared technology and the age of the components. Some RCA universal remote controls will only work with components manufactured after 1990.
Distance
If you are testing the remote control after you have entered a code, you may be too far away from the component or you may not have the remote control aimed directly at the component. Because the remote control uses infrared (IR) technology to communicate with components, there must be an unobstructed path between the remote control and the IR sensor on the component.
Code Entry Methods
If the Direct Code Entry method was used to enter the codes for your brand and the unit is still not functioning properly, try one of the automatic code search methods instead. During automatic code search, the remote searches for the correct code to program.
Modes
For the remote control to know which component you wish to operate, you must put the remote control in the correct mode by pressing the corresponding component button.
Combo Units
To program the remote control to operate combo units, such as TV/VCR’s, TV/DVD’s, or TV/VCR/DVD’s, use the combo codes in the Code List to program the individual corresponding component buttons. Once programmed successfully, the TV button controls the TV functions on your unit, and the DVD or VCR button controls the DVD or VCR functions, respectively. The codes in the combo section should be tried first, using the Direct Code Entry method on the TV and DVD or VCR buttons. If this is unsuccessful, use one of the Code Search methods to program your combo unit.
Batteries
Make sure the batteries are new and properly installed.
on Jun 19, 2009 | RCA DIRECTV Satellite Remote Control
Does anyone know what the universal remote control code for the Dion Digital set top box? (Model STB2AW09)
Try AK59-00104R. The Samsung AK59-00104R full-function or Universal remote control to operate varios devices and you can program the remote control to operate most of the popular brands of audio/video equipment like a TV, a DVD player (or VCR), or a Network satellite receiver. See Programming for Other Equipment on This remote control may have features not used by your receiver.
http://www.directutor.com/sites/directutor6/files/RemoteManual/AK59-00104R.pdf
Sep 23, 2011 | Samsung TV Set Top Box Remote Control
Don't know how to set up for any tv need instruction booklet
don't know how to set-up or program the code (1047) for a RCA tv. using URC-3021 remote control
Jul 10, 2011 | One For All URC-3021 Remote Control
We have an old Sharp TV and lost the remote control. Can I use an RCA remote control to operate the Sharp TV - and what codes would I need - and how to do it. Thanks
I don't know from which country you are? But remote control of almost every TV is available in electronics spare part market. Just check it in your country. All that you have to do is carry your old remote control with you while purchasing a new one. It is better to tell them the make & model number of the TV.
sonsunny
Jun 17, 2011 | Sharp Televison & Video
How do I get to video mode on my disney princess tv? I dont have a remote
Sorry to be the bearer of bad news on this but you don't have the remote for this TV, you're out of luck. This is one of the many problems with this TV. The other is that there is not a universal remote control in existence that has codes or signals programmed into it to operate it. I know all this because I've gone through the exact same issues with it as my daughter has this TV. So unfortunately, you're stuck.
May 28, 2011 | Audio Players & Recorders
Remote want work on tv
Make sure that you're using the supplied Remote (RMY-906) to control the TV. If so, perform the steps given below to resolve the issue.
  • Make sure that you're using batteries which are having enough charge. Try using fresh alkaline batteries.
  • Do not use rechargeable batteries in the Remote.
  • Ensure that the batteries are inserted correctly with the correct terminals by checking the + and - symbol in the battery compartment.
  • Make sure that the Remote is set to operate with the correct functions. On the remote control, press the TV FUNCTION button to re-check this.
  • Press the POWER button and other buttons to test the operation.
  • Make sure that none of the buttons are jammed in the remote control.
  • Ensure that the remote control is being used no closer than 3 feet and no further than 10 feet away from the unit. Try using the remote control at varying distances from the TV.
  • When using the remote control, be sure to point it directly at the remote sensor on the device.
  • Remove any obstacles that may be in the path between the remote control and the device.
  • Ensure the remote sensor of the device is not exposed to direct sunlight or bright florescent lights, as this can interfere with the sensors ability to receive signals from the remote control.
  • Try resetting the Remote. To reset the Remote. remove the batteries from the remote control, press every button twice, and then reinstall the batteries.
  • Try resetting the TV also to check the operation. To reset the TV, disconnect the power cord for a short period of time (approximately 1 minute), then reconnect the power cord and power on the television.
If the remote control is able to operate other devices (such as cable box, DVD Player or satellite receiver), then the issue may be with the IR sensor on the TV. If this is the case then the TV that will require service. Otherwise, the remote control may need replaced.
Good Luck!
KenSolutions
Nov 23, 2010 | Sony KP-61S75 TV
Sky remote control code for LG tv
Can you provide me with a set up code for my Sky remote control to work my LG LCD tv model no. 32LG3000?
Many thanks
Jan 09, 2009 | Televison & Video
How do I get Philips control for a DVD Recorder operate a Sony TV
You can ask this to PHILIPS SERVICE CENTRES. They will do if possible. else ask to SONY SERVICE CENTRES.
Jan 02, 2009 | Philips Magnavox Learning Universal Remote
Fan remote operates fan, won't operate light
If you press and hold the light button, it will step up in brightness to max then back down to dark. Then when you press the button briefly it will turn off and then press button briefly again it will turn on at the intensity you had it at last. So if you are one tick from off you may not notice it is "on" because it is dark. A second possibility is that you replaced the bulbs with a compact flourescent and they are not always happy with adjustable brightness, often they will be on or off, no middle ground. I recommend sticking with old school bulbs in the fan.
Sep 21, 2008 | Universal Remote Control Hampton Bay...
LG 37LG30 37 in. LCD HDTV Logo
69 people viewed this question
Ekse
RONALD CARTER JR
