Washing Machines Logo
A
Anonymous Posted on Jul 31, 2014
Fault 49 Fisher and Paykel Aquasmart
Greg Stephen
Level 2:
  • Fisher and P... Expert 566 Answers
  • Posted on Dec 14, 2014
Greg Stephen
Level 2:
Answers
566
Questions
Helped
224762
Points
688
The main board is displaying the wrong error
for the problem your machine has.
Fault 49 is water valves error.
The most common problem with AquaSmart is pump faulty
and damaged your motor control board,
Pump and motor control board need replacing.
4 Related Answers
Anonymous
  • Posted on Nov 18, 2009
SOURCE: fisher@paykel aquasmart WL80T65CW1 fault code245
hi my fisher & paykel aquasmart has a message saying fault 49 what does this mean?
luisa_sgro
  • 713 Answers
  • Posted on Apr 08, 2010
SOURCE: I put a small Carpet piece in my Fisher and Paykel
could b faulty control module. when pump jams or seizes on these machines it usually causes a fault in control module.whenever i found a control module faulty i always checked the pump for cause of fault.
Anonymous
  • 10 Answers
  • Posted on Jul 11, 2010
SOURCE: fault 49 smartdrive
Hi have had this problem on phase 5 grey controller, on the controll board near where the valve hot and cold wires are connected you will see a small usually blue resistor value approx 5ohms this is probably open circuit replace it check your water valves before reconnecting I was fortunate enough to have plenty of spare valves so I just replaced both valves as I suspect a faulty one may have damaged resistor machine has been working fine for some time since
Anonymous
  • 15935 Answers
  • Posted on Sep 14, 2010
SOURCE: fault code
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
1helpful
Fisher & Paykel WL26CW1 - Error Code 49! can i swap the hot and cold valves to make it work and disconect the hot valve?? and love this site very informative, Thanx Guys..
The most common problem with AquaSmart is the pump
not the water valves
The pump has gone bad and blown some parts in the motor controller board and the fuse to the water valves.
Some AquaSmart machines display the wrong Error code (49)
witch is not the correct code for this problem.
Pump and motor controller board need replacing.
Maybe cheaper to buy a good secondhand machine.
Need a service, fault 49 ???????
cold valve fault. check the water supply, check the valves. otherwise it's the motor controller. replace parts as necessary.
Fisher paykel aquasmart fault 49
Fault code 49 is water valves, But the Aqua-Smart board is outputting the wrong code here, The Smart pump has blown the water valves fuse, A common thing in Aqua-Smart Machines.
The Smart pump has jammed with lint and caused over current to the board and taken out parts on the board that drive the pump.
Best to get a new/recondition board for your machine.
1helpful
Fisher paykel aqua smart fault 49
TO FIX CODE 49 AQUASMART WASHINGMACHINE FISHERNPAYKEL
Yes you are right the pump in AquaSmart machines blows the water valves fuse that give you fault code 49.
I put a small Carpet piece in my Fisher and Paykel Aquasmart WL80T65CW top loading washing machine. It disintergrated and the machine stopped displaying "I need service Fault 49" I have removed and...
27helpful
2answers
Fisher@paykel aquasmart WL80T65CW1 fault code245 and code49
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
