After flushing the cistern seems to fill very slow even when fill tap is on full. I have checked the hose and it is all clear.
SOURCE: Loud hammering noise with vibration on piper when the cistern fil
You're experiencing "water hammering" it's solvable too.
You can buy anti-hammer add-ons which you can put under a nearby sink, or even on an outside hose bib. This will give the water pipes an air "shock absorber"... since air compresses it cushions the abrupt changes in the pressure where as if it's just water, it'll slam and hammer and vibrate...
Try an anti hammer device added to you supply... you should be able to add it with out too much tearout.
K
SOURCE: hi, i have a caroma duel flush toilet possibly 10
First make sure it is not overfilling. The water level must stop before it reaches the overflow pipe. If it continues to run it will overflow into the bowl and continue to run. Adjust the fill level to the mark inside the tank. Make sure nothing is getting under the flapper and holding it open. You replaced the flapper so we know that is not the problem. Just make sure the flapper is centered on the drain hole.
SOURCE: cistern leak
The flapper valve(ball)seat is not sealing. Needs a new seat and flapperat bottom of tank. -Ned-
SOURCE: I have an old Caroma Dual flush ( 15-20 years) and
Well luckly the velve can be replaced by a modern 1. iets not exspensive and dosent take long to do, u will get a step by step apon perches.
Plz rate my advice
