SOURCE: Paper jam on HP officejet 6500
Try This :
Connect the printer directly to the wall outlet ; not through any Power strip
Then Unplug the Power cable from the back of the printer
Keep on tapping the power cable for next 30 seconds
Plug in back the power cable;
Open the rear access door and you will get to see some rollers
Clean the rollers with a Lint free cloth Moistened with some distilled water
Try to do a copy if still it doesn works
With one hand press and hold down the (#) and the (6) button and with the other hand plug in back the power cable ; it will do a Semifull reset on the printer; This will take some time ; Follow the instruction on the screen;
If still it doesn't work then you need to contact HP ;
The toll free no. for HP would be : 1-800-474-6836
They will replace the printer for you free of cost (No Charge if the printer is in warranty i.e within 1 yr of purchase)
Still you may check the link below for further issues:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01312792&lc=en&dlc=en&cc=us&lang=en&product=3795406
Regards Soumajit
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue
The Out of Paper
message appears on the computer and the product stops picking up or feeding paper.
Solution
Step one: Reset the product
Step two: Check the condition of the paper and reload it
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
NOTE:
Do not load too much paper in the product.
Step four: Clean the rollers
Step five: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
CauseAny of the following issues can cause the error message to appear:
SOURCE: HP Officejet 6500 No scan Options
I am trying to scan, but when I press the scan button it states "No scan options. Refer to device doc to troubleshoot". However, I can't find my device doc. I am assuming there is an easy fix?
SOURCE: paper jam on a officejet 6500 wireless
Unplug the power cord and open the cover and remove all the cartridge and try to look I inside around the roller and try to manually roll the roller and if you can see the paper try to pull is slowly.
Have a nice day and do not forget to rate please...!
SOURCE: I am looking for a fix on hp officejet 6500 E709a
To clear jam , you can perform the link below
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01312792&cc=us&lc=en&dlc=en&product=3795314
if still you get the message, remove the cartridges from printer.
clean them with a cotton swab and distilled water and perform the steps below and once it is done, insert the cartridges when asked by the printer.
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold Plus (#) and 6 while plugging in the power cord.
