Hard wiring simply provides a trickle charge to the battery. If the battery is depleted, you may have to take it out and recharge it independently, then put it in. A trickle charge is not a fast way to charge a battery and if the battery is low, there may be insufficent power to operate the Ring 2. It has to have the battery for it to work any significant length of time. The hardwire alone is insufficient. Fully charged battery? That's not the same as a new battery. An old battery may not be holding the charge in spite of initially testing at 100%.
Is the doorbell battery working? If you don't have sound, it can be the speaker or the speaker amplifier. Water damage can also cause the microphone outsiade to not work. You have to be a bit more specific. Is it just the bell that is dead or can you still hear sound over the microphone?
Wireless Doorbell CD Quality Door ChimeModel RC4300
No longer do you need a wired door chime or traditional doorbell with brass tubing to get amazing, rich sound. Our Battery Operated Door Chime from Dimango has CD quality sound while remaining completely wireless...
the radio runs off of a seperate battery source, so that wouldn't have any effect on this, i would first of all check the battery and charger with a multimeter and make sure that they are showing the correct voltage, if its a 12v battery make sure that they are showing at least 12 volts, if its a 6v battery make sure that its showing at least 6v
Link to the mattel site: http://service.mattel.com/us/product_detail.asp?id=N7666&Ntt=N7666&Pn=7&Brand=Barbie&Cat=Barbie+Accessories%2FFashions%2FPlaysets
Opens up a windows. Click on both avaialbe PDF's and download to your pc.
The doorbell buttons and your receiver must be on the same channel. If you will get out the directions that came with your unit, they will describe the process to go through to reset the specific "codes" for your buttons and receiver.
Troubleshooting Chime does not sound: • Make sure the doorbell button and the chime codes are the same (See pages 2 and 3). • Check orientation of doorbell button battery (See page 3). • Check the doorbell button and chime batteries, replace if necessary. Batteries seem OK, but the chime does not work when installed: • Do not mount the chime or doorbell button on metal or near metal studs. This reduces the transmitter range. Use 1/4" to 1/2" (6 to 13 mm) wood shims to move the chime or doorbell button off the metal surface. • Don't mount the chime too close to ground level concrete slabs. This may also reduce the range. Mount the chime away from the floor. • Try different locations for the chime closer to the doorbell button. Also try to orient the chime at a different angle to increase the range. The range of the doorbell depends on location, temperature and battery condition. Regulatory Information This device complies with Part 15 of the FCC Rules and RSS-210 of Industry Canada. Operation is subject to the following two conditions: (1) this device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation. The user is cautioned that changes or modifications not expressly approved by the party responsible for regulatory compliance could void the user’s authority to operate the equipment. Technical Service Please call 1-800-858-8501 (English speaking only) for assistance before returning product to store. If you experience a problem, follow this guide. You may also want to visit our Web site at: www.hzsupport.com. If the problem persists, call* for assistance at 1-800-858-8501, 7:30 AM to 4:30 PM CST (M-F). You may also write* to: HeathCo LLC P.O. Box 90004, Bowling Green, KY 42102-9004 ATTN: Technical Service * If contacting Technical Service, please have the following information available: Model Number, Date of Purchase, and Place of Purchase. No Service Parts Available for this Product
