Freezers Logo
A
Anonymous Posted on Jul 31, 2014
What is the capacity of whirlpool freezer AFB 823/3
1 Related Answer
Anonymous
  • 5 Answers
  • Posted on Feb 21, 2011
SOURCE: My Whirlpool Intergrated Freezer AFB
This one requires more information. If the breaker trips randomly, then I say there is grounding problem between the plug and the freezer itself. I know the UK has a very large plug and it requires a serious connection into the wall. I would check and make sure you have a good ground on the box itself. You may have to removed the back and look at the connections If you have a V-OHM meter you can verify the ground through different parts of the freezer. If this never happen before and you just bought this freezer I would replace the breaker with a new one. The breaker maybe damaged and sensitive to heat from the current draw of the freezer. Also make sure it is the correct ampere required to run the freezer.
How many cubic feet is model #EV190NXWN00?
The 19 in the model is the cubic ft capacity of that freezer.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
What indicate liters in freeze?
The liters indicate the storage capacity. The more liters there are, the higher the strage capacity.
2answers
Capacity of Kenmore Freezer Model 253
I would like to know the capacity of my freezer
My Whirlpool Intergrated Freezer AFB 823/3 trip The Earth Leakage CB on the house Fuse board!!
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
My whirlpool afb 6640 freezer has a red light on
thermostat is defective(loose contact)
May 09, 2009 • Freezers
Whirlpool upright freezer turning itself off
hi,my name is sourine,i have a probrem with my freezer not cool at all,it's about20 year old.
BRAND WHIRLPOOL
model EV150N A O
14.6 c.f
Top Whirlpool Freezers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
