WILL IT MOVE IF PUT IN LOW GEAR? ( SHIFTR ALL THE WAY DOWN) AND IS REVERSE WHERE IT SHOULD BE AS FAR AS GEAR INDICATOR?
If I remember correctly reverse and low (1) use the same clutch pack.
WE CAN ONLY SPECULATE WHAT THE PROBLEM IS.
YOU NEED SOMEONE TO "LOOK" AT THIS FOR YOU.
woops sorry cap locks were on. not yelling.
This is one way I've found to delete an email stuck in the outbox (which is what it "sounds like" you are asking...)
1. change ya smtp settings so the message defo wont send!
2. send a test email to anyone
3. it will attempt to send but oversiously fail...
4. hopefully the outbox should be listed with 1 message waiting to go out...
5. if not, try going into the Activity Window and canceling the send command, that should show it up...
6. click the Outbox and the will be one message listed...
7. goto View -> then Show Favourites Bar
8. you should see a favourites bar appear...
9. simply drop and drag the Outbox into your favourites bar...
10. if you restart ur laptop or close mail and then the Outbox has disappeard, simply click the Outbox in you favourites tab and woop woop it should appear in the Side Bar
Sounds like a balance problem or there is a flat spot in the tire. I'd have a tire shop take a look at it, but you can also try and rotate the tire to the rear and see if the noise follows the tire.
Sounds like the A/C compressor clutch has overheated and become inoperable. Open the hood, start engine, observe the compressor face. It should be turning and also see if that's where the noise and burning smell is coming from. Good luck!!!
That's what it sounds like to me also. I would put the rear up on jack stands and spin the wheels to male shure wich side it is. Don't forget to block the front wheels for safety as you will not be able to set your e- brake for this test.
