There is a dead short line to line or line to ground. The dead short can be detected with a electric continuity tester connected across the load side of the mains (power shut off) and opening covers and inspecting the wiring.
No i dont but i could suggest you check the heating element and the clixon that connects to the evaporator. If the heater does not function, it takes a much longer time than usual to switch the freezer on.
the stat is clamped to the backplate of the frodge with a simple clamp held just by two screws. undo the clamp. the stat capiliary may be bent back on itself, if so straighten it and it will pull out
AUTOMATIC AC/DC CHANGEOVER: All Engel Fridge Freezers can be plugged
into both AC and DC at the same time. The Engel is smart enough to use
the AC while available and then automatically switch to DC when the AC
is no longer working. It will also sense the resumption of AC power and
automatically switch back to AC making it ideal for high hurricane areas
and places where power disruption is common. Read more: http://www.roadtrucker.com/engel/engel-12-volt-fridge-freezer-technical.html#ixzz2MvRL2xrC
check that the correct thermostat is installed and that the element wire is connected.check door rubber and door hinges.check if it has independant defrost timmers and if it is working.oh and see if the element is drawing current if fitted with one.
