Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Please provide model number and also the condition when this error occurs. Can you operate the oven after this fault occurs. Try to turn off the mains power and check after turning back on.
Hello - Could it possibly be error code F13 or F36? According to my research this manufacturer does not have an error code F136. Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and see if the error code clears. If it proves to be ineffective, contact a professional to move forward accurately to properly diagnose the unit.
The error code F6E5 means "Cancel key error". Press the "Cancel" and "Start" keys in the following order: CANCEL, CANCEL, START. Verify the error code displayed on the control by observing for longer then 1 minute. If the error comes back then the control board needs to be replaced..
If this was helpful please rate me Thanks
