Hello.Best to use Cotton dry you are correct!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
SOURCE: noisy drum
You may have a rear drum support issue. There are 2 rollers,(supports), 1 at 4 o'clock and 1 at 7 o'clock. If the bushing in the roller becomes elongated,(elliptical), it will give a thumping noise, as you describe.
Below is a link with exploded diagrams and parts help.
http://www.repairclinic.com/0100_14.asp
Please rate my answer on how helpful it was in resolving your issue.
Thank you,
Dave E. (Illeagle)
SOURCE: husband drying sneakers in dryer - dryer stopped will not restart
check fllowing -
Door switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Good luck.....
SOURCE: electric whirlpool dryer turns & heats but does not dry
the flames on the dryer come on for a couple of minutes and then shut off then comes back on about 5 min. later,. the cloths don't get dry . this goes on the whole time the dryers running, take 2hours to dry a load of cloths
SOURCE: MODEL PBSR353EWOWW. Dryer is functioning but...in
One or more of your heating elements is probably out.
I have a repair album with photos and a manual HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
