What fuses does it need and where can i get them from
I'm guessing you don't know for sure that it even needs fuses. They don't go out like they used to, as everything is controlled by a microprocessor(computer within your unit). I would suggest, that you, with the power plug pulled out, use an ohm meter to be sure that each fuse is shorted. If you need further assistance, or would like to inquire about a repair, please visit my website at audioserviceclinic.com. Thank you.
SOURCE: Problem with Rotel RA 870
Since it is a Rotel, it is a good unit and worth fixing. At this point, you need to take it to a good repair shop and let a qualified tech look at it. There are no user serviceable parts inside and if you go poking around in there, you WILL make the problem worse. Rotels' are nice units and represent a good value in stereo gear. Take it to a reputable repair shop that repairs Rotel under warranty. If thats not available to you, then a good repair shop should be able to get you going. Good luck...Rob
SOURCE: the two 5 amp fuse inside the amplifier keeps blowing
That must be the inrush current.
Maybe you are using the wrong fuses.
Please check if those are fast or slow types.
You need slow types.
Good luck,
Gerard
SOURCE: My Rotel RA-935BX blows out the fuse on the power
It seems you have a short circuit in your unit. Further attempts at switching it on are not advisable as more damage will occur. Get it checked out by an electrician who can test from the plug for a short circuit.
SOURCE: My rotel model ra-870bx keeps blowing the fuses I
check power amplifier component one should leak or damage so your power consumption is too high
SOURCE: HALLO I HAVE A ROTEL RA 9858X AND AGTER PLAYING FOR A FEW MINUTES I LOSE THE RIGHT SPEAKER CHANEL
Try interchanging the speakers. If the right channel works, you have a problem with your speaker.
Testimonial: "the speakers work dhecked with ather amp"
