1978 Wilderness Prices, Values and Specs
Building travel trailers as well as fifth wheel trailers for the first time in the 1970s, recreational vehicle brand Wilderness designed as basic family vacationing and camping. Wilderness would also produce park model vacation units from 1994 to 2002 measuring up to 40 feet in length. A division of Fleetwood, Wilderness was discontinued after the 2009 model year.
That needs to be done on a machine and all the components of the front end checked for wear, also tweets to the specs may be needed to attain the desired results of a straight steering vehicle.
evinrude 1978 -1979 have a capacity discharge ignition unit as the control for the spark system
it runs wires to an ignition coil
so I would be suspicious of that unit
check all connections for corrosion and bad connections
I typed in electrical schematics for 1978 evinrude out board engine and found a site --www.maxrules.com which in the list of schematics has 55hp 1977-1978
press on that and you get a schematics of the wiring diagram evinrude 1978-1979 55hp
now I am aware that you state that yours is 35 hp but if it has 2 cylinders then it is a fair bet that the wiring diagram will be the same
any way there are plenty of other sites that may be of benefit
All specifications, performance and fuel economy data of Lincoln Continental Town Car 460-4V (156.5 kW / 213 PS / 210 hp), edition of the year 1978 since ...
170 ft.lbs is the minimum; be aware that this differential uses a crush sleeve to set the backlash and the pinion torque is what crushes the crush sleeve. If you don't set the backlash correctly you can grind up your differential gears. 8 Inch Ford Rear End Torque Specifications eHow
You may have this
posted in the wrong product category. Please select another category
appropriate to the problem and re-post the problem so the correct
expert will see and respond to the question..
If i were you i would not do this mod. You are going to end up with a ugly top triple tree. Rather find a lower set of bars off another bike. They are all the same diameter tubing.
check the neddle valve seats under the float bowls,may find that theseats are not sealing,to test,take the carbs off the bike,remove the bowls ,compress the floats untill they are all the way up(simulates full bowl of fuel)then blow through the fuel inlet pipe,you should not be able to hear air passing throgh the valve if you can replace the valve seat and the needle valve,sorry cant remember point settings,long time ago since i worked on one of these
