Question about HP PHOTOSMART PLUS B209A All-In-One Printer
Copy function not working. pprinting solid color lines throught the whole paper. hp photosmart b209a
5 Suggested Answers
SOURCE:
buffalonyman
  • 1865 Answers
SOURCE: HP Photosmart 3310 All in One - just failed
Go to the following link to get support for your printer
http://h10025.www1.hp.com/ewfrf/wc/product?product=439491&lc=en&cc=us&dlc=en&lang=en&cc=us
Posted on Nov 05, 2009
Testimonial: "Straightforward answer & appropriate link!"
  • 3 Answers
SOURCE: HP Photosmart Plus B209a-m scanning problems
  • Click the Start button , click All Programs, and then click Windows Fax and Scan.
  • Click Scan at the bottom of the left pane.
  • On the toolbar, click New Scan.
  • In the New Scan dialog box, click the Profile list, and then choose Documents. The default settings for scanning a document, which you can use or change, are automatically displayed.
  • To see how your document will appear when scanned, click Preview.
  • Click Scan.
  • Posted on Jul 08, 2010
    SOURCE: my hp photosmart C4780 printer
    While the print function will still work, the copy function won't work if ink is low.
    Posted on Oct 04, 2010
    Testimonial: "OK Tks for the hint..it was one of the alternatives"
    • 693 Answers
    SOURCE: MY HP 8500A HAS STARTED
    Solution one: Reset the product If there is static interference, or loose connections with the product, this can result in bands or lines in the copy, fax, or scan output. To resolve this issue, check the product connections and reset the product Press the Power button (c01602202.gif ) to turn on the product.Disconnect the power cord from the rear of the product.Unplug the power cord from the wall outlet.Wait 30 seconds.Plug the power cord back into the wall outlet. Reconnect the power cord to the rear of the product.Press the Power utton (c01602202.gif ) to turn on the product.Try to copy, fax, or scan again.If these steps resolved the issue , you do not need to continue troubleshooting.If the issue persists , continue to the next solution.
    Solution two: Clean the scanner glass and scanner lid
    If the scanner glass or the white underside of the lid has fingerprints, smudges, lint, dust, or other debris, this can slow performance and affect copy and scan quality. To resolve this issue, clean the product.Before you begin, gather the following materials:Several clean, soft, lint-free cloths
    Mild glass cleaner
    CAUTION: Use only glass cleaner to clean the scanner glass. Do not use cleaners that contain abrasives, acetone, benzene, or carbon tetrachloride. These substances can damage the product. Avoid isopropyl alcohol (rubbing alcohol) because it can leave streaks on the glass.
    1. Press the Power button (c01602202.gif ) to turn off the product.
    2. Disconnect the power cord from the rear of the product.
    3. Lift the scanner lid. Figure 3: Lift the scanner lid
    4. Spray a clean, soft, lint-free cloth with mild glass cleaner.
      CAUTION: To protect the scanner, do not spray the glass cleaner directly on the glass.
    5. Clean the scanner glass with the lint-free cloth. Figure 4: The scanner glass
    6. Clean the glass strip next to the scanner glass with the lint-free cloth. Figure 5: The glass strip
    7. Dry the scanner glass and the glass strip thoroughly with a clean, dry cloth or chamois to prevent spotting, and then dry the white underside of the scanner lid.
      NOTE: Do not use paper-based wipes or tissues that can leave fiber residue.
    8. Clean the white underside of the scanner lid. Figure 6: The underside of the scanner lid
    9. Close the scanner lid.
    10. Reconnect the power cord to the rear of the product.
    11. If the product does not turn on by itself, press the Power button (c01602202.gif ) to turn it on.
    12. Try to copy, fax, or scan again.
    • If these steps resolved the issue , you do not need to continue troubleshooting.
    • If the issue persists , continue to the next solution.
    Solution three: Clean the automatic document feeder (ADF) Use the following steps to clean the automatic document feeder. Step one: Clean the ADF rollers and separator pad
    1. Gather the following materials:
      • A clean, lint-free cloth, or any cloth that will not come apart or leave fibers
      • Distilled, filtered, or bottled water (tap water might damage the product)
    2. Remove any documents from the document feeder tray.
    3. Press the Power button (c01602202.gif ) to turn off the product.
    4. Disconnect the power cord from the rear of the product.
    5. Lift the cover of the ADF until it stops. Figure 7: Lift the ADF cover
    6. Find the pick rollers and separator pad. Figure 8: Locations of the pick rollers and separator padLightly dampen a clean lint-free cloth with distilled or bottled water, and then squeeze any excess liquid from the cloth.
    7. Use the damp cloth to wipe any residue off the separator pad.
    Posted on Aug 14, 2011
    Can my printer be made WIFI?
    If you have a USB port yes. You just need to buy a wifi to usb print server. Any decent computer store will sell them. You will quite likely be limited to printing as often the scan functions do not work with the prints servers.
    Sep 03, 2014 | HP Photosmart Plus B209A All-In-One Color...
    How do i change the ssid on my photosmart plus b209a-m printer
    Step 1: Click on Windows icon (bottom left hand screen)
    Step 2: Select Devices and Printers
    Step 3: Right Click on "HP Photosmart Printer Plus B209a-m"
    Step 4: Select "Printing Preferences"
    Step 5: Click on Tab "Features"
    Step 6: Select "Printer Services" in the bottom right hand corner
    Step 7: Click on tab "Network Settings"
    What you click on there depends on what's wrong with your setup, I think. Mine had a "Configure Wireless" option where I was stepped through the process.
    Good Luck!
    Jul 10, 2012 | HP Photosmart Plus B209A All-In-One Color...
    Wrong language accident put printer in "Korean" of
    You need uninstall first software driver of HP PHOTOSMART PLUS AIO PRINTER B209A PHOTOSMART PLUS AIO PRINTER B209A All-In-One. and Then reboot your PC. then install again software driver for that printer select English language version.
    Oct 16, 2011 | HP PHOTOSMART PLUS B209A All-In-One...
    I have a photosmart B209a printer that produces small lines on my pictures. I replaced the ink thinking it might be that easy, but no dice. Any ideas for cause and cure
    I had a similar problem initially and the fault was with the photographic paper. The lines were very regular, just over 1cm apart. Once I switched to HP Advanced paper it cured it.
    Jan 14, 2011 | HP PHOTOSMART PLUS B209A All-In-One...
    HP Photosmart C3180 prints a solid black line left side of paper ONLY when you COPY. When you print from computer, it prints just fine. It is only from COPY mode that the solid black line appears.Already...
    Unfortunately, your C3180 printer needs some repairs done to it or you . A section of the printing arm that does the printing is faulty. This happened to me and apart from replacing the arm (at considerable cost) I purchased a new printer at a much cheaper cost. You can use your faulty printer for printing from the computer but not for copying or scanning. MG
    Jun 08, 2009 | HP Photosmart C3180 All-In-One InkJet...
    All copies and scanner outputs result in a totally black image
    hi,
    its could be hardware issue, if you tell me which printer, then we can try some reset on that machine..........
    Regards,  raj_p5983
    Jan 23, 2009 | HP PhotoSmart C4180 All-in-One Color...
    3050
    when we copy or scan we get lines at both side throught
    the paper
    Apr 15, 2008 | HP LaserJet 3050 All-In-One Printer
    HP PHOTOSMART PLUS B209A All-In-One Printer Logo
    Clive
    Clive
    Thomas F. Schneider
