Jura Capresso Impressa F7 Espresso Machine Logo
A
Anonymous Posted on Jul 30, 2014
I have a jura capresso impressa f7 machine and when I cleaned it (using cleaning tablet) it made some strange sounds and the screen reads "Fault 8" - I removed the tray and cannot re-insert it as the mechanism (that possibly measures the coffee ground level?) seems to have disengaged and is blocking me from reinserting the tray. What can I do to fix it?
Edward Harris
Level 2:
Scholar:
New Friend:
  • Expert 78 Answers
  • Posted on Oct 23, 2016
Edward Harris
Expert
Level 2:
Scholar:
New Friend:
Answers
78
Questions
0
Helped
85539
Points
189
The error 8 means the brew group has not returned to its home (start) position.
With tray removed, insert your hand under the machine. The bottom of brew group may be with coffee grounds that have been there to prevent brew group not returning to its start position. Use a small rag to clean the bottom of the brew group.
Jura does not allow manual cleaning of brew group to keep it clean & Fungus free.
Please watch videos posted on You tube channel Parts Guru USA. Videos show you how to open and manually clean the inside of machine, specially the brew group.
Sometime the used coffee scraper can get unhooked and come in the way of
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Theo
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 22, 2014
Theo
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
860
Points
There is a liver on right hand side push it in and hold until it finishes process. reason why you cannot push the tray in is because you have taken it out half way trough the process.
Ruth Baldwin
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Jul 30, 2014
Ruth Baldwin
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
Helped
8809
Points
43
Check to see if there is a lever that may need pushed in as you put the tray bad in...not sure as many of the machines are different...but it's worth a try! :)
1 Related Answer
Anonymous
  • Posted on Dec 30, 2007
SOURCE: Jura Capresso Problem
check out this link:
http://www.kuntze.de/E/index.htm
Turning dial after choosing strong, we want 4 oz, but turning dial toward 4 it may goe to 5 and then up to 7 down to 6, up to 8, etc.
Operating Manuals - Jura Capresso Coffee Machines
capresso.125west.com/html/operating_manuals.html
Operating Manual Impressa F9 and F9 Limited Edition. Operating Manual Impressa F7. Operating Manual Impressa E8. Capresso C1300 Superautomatic ...
1helpful
Water in disposed coffee container jura impressa z5
You may have to clean the unit using cleaning tablets, also there is a flap in the bay (remove the tray and use flashlight, sometimes it cakes up and moisture collects. Final thought is you may need to send it in to Capresso/Jura for service. Mike
Jura impressa x7 does not rinse and coffee does not come out. I do get steam for froth etc
Jura x7 coffee machines are older models in the coffee machine range. It may simply require a full system clean, using jura cleaning tablets, or more likely a service. Bean to cup machines should really be serviced every year to 18 months depending on usage.
We can put you in touch with a Jura engineer if you need one, contact me here Denby Dale Coffee
1helpful
2answers
Error message Fault 5
The message 'FAULT 5' on the Jura Impressa F7, appears when there is a problem with the heating sensor. Normally it needs service or replacement. You can try to unplug it from the power supply for an hour and then open it again. See if it works.
1helpful
Jura fault 1
According to the Jura Coffee Machine Error List, you machine needs a service, have you made 5,000 cups since your last service?
Malfunction 8
The brew unit having problems with positioning it self. Use your finger and clean out all used ground from the brew unit you can find. Start the cleaning program with tablet, hopefully you will get around the error code.
Jura Capresso C3000 keeps saying clean unit
We have the S8 here at our office. Ran the cleaning cycle and "Clean Now" message was still on and beeping afterwards. Read the Feb 28 comment and carefully cleaned everything that had grounds stuck to it. Ran the cycle again and it worked. Thanks all.
3helpful
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Grand Canyon Tech
Grand Canyon Tech
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
