Dayton Wire Wheels Dayton Electric Pallet Jack Red Steel 24v Logo
A
AnythingNow Posted on Jul 30, 2014
I have a Dayton electric pallet jack the red lights are flashing on and off and it won't raise up but will go forward and back and if fully charged?
Ruth Baldwin
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Jul 30, 2014
Ruth Baldwin
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
Helped
8798
Points
43
This YouTube video may help you out! :)
https://www.youtube.com/watch?v=L2KU_po36Lo
1helpful
Toyota electric pallet jack don't go forward
Depending on what type of forward reverse Leaver is on your pallet Jack, it sounds like it has a bad connection, or needs replaced because the connections are worn out from use, or a fuse needs replaced.
I have a 36ft winnebago Chieftain on a F53 chassis. I need to replace the fuel pump in the tank but the leveling jacks seem to go around the tank any idea how I remove them to get to the tank. If at
I dropped the tank on a 34' Fleetwood with the same situation. The jacks were welded on so there was no removal option. What I did was (1) Cut eight 4x4 s into 12" sections. I bolted 4 sections together to make a "pad". One 8" 4X4 makes two pads. (2) Then I pumped the fuel into drums. Free drums are easy to find. A cheap 12V fuel pump and tubing is available from any auto supply. (3) I raised the camper on all 4 jacks. Than I retracted one jack, set a pad in place under it and extended the jack fully. Clockwise I put pads under all the jacks one at a time to make a layer. Then I put in another layer of jacks, round and around, and continued until the camper was up 4 layers. (4) The camper could "roll" forward off the jacks at this point because the wheels were off the ground. I attached a chain to the camper frame and took tension backwards using a come-along chained to a tree. (5) Then I got some pallets from the grocery store trash and put those under the tank. (6) I loosened the hangers for the tank and let it down on the pallets slowly. The hoses have to be removed before the tank drops very far. I worked the pallets out one layer at a time to lower the tank to the ground. (7) I could reach the pump mounting plate so I just removed the screws and lifted out the pump and gasket. (8) installation was the reversal.
If I had to do it again, I would take it to Camping World or a truck garage. They have lifts to raise the camper and jacks to raise and lower the tank.
Are there any other common names for pallet jacks?
Pallet jacks may also be called pallet trucks, pump trucks, or jiggers
May 27, 2013 • Hoisting
What are the common specs for the forks on pallet jacks?
fork width= 7 inches
fork length= 36, 42, or 48 inches
fork height= 2.9 inches
fully raised height= at least 7.5 inches
length between outer edges of forks= 20.25 or 27 inches
Jan 16, 2013 • Hoisting
Code c-14 for toyota electric pallet jack
toyato pallet jack electric , DISCUSSION FORUM - Forkliftaction.com
www.forkliftaction.com/forum/thread.asp?trid=15922
Dec 24, 2014 - 4 posts - ‎2 authors
California, United States, I have 7hbw23 toyota pallet jack with error codes c14 and e115 e112 trying to find code list or repair manual any ... toyota pallet jack . Discussion about troubleshooting ...
Dec 30, 2014
Error Messages for Walkie 102XM. Discussion about ...
May 6, 2009
More results from www.forkliftaction.com
Forum discussions - FORKLIFTACTION, Search this ...
www.forkliftaction.com/search/search_results.aspx?searchall=y...3
RESULTS 1 - 20 - 7HBW23 pallet jack no power, no fault codes. Lifting machines ...Toyota Electric pallet jack. Lifting machines ... error code C-28. Mechanical ...
toyota forklift manual 7hbw23 code c14 pdf - P(1) - srdt.sotite ...
srdt.sotite.com/pdf/1/toyota-forklift-manual-7hbw23-code-c14.html
Toyota electric pallet jack 7hbw23manual.pdf - WordPress.com ... I have 7hbw23toyota pallet jack with error codes c14 and e115 e112 trying to find code list or.
Code c-14 for toyota electric pallet jack - Fixya
www.fixya.com/cars/t12123378-code_c_14_toyota_electric_pallet_jack
Mar 22, 2012 - I have code c-14,try to fix it ... Hi Danny: One of the things that I do is to try to help resolve the problem, and that does not always mean answering ...
Mar 22, 2012 • Hoisting
Top Dayton Wire Wheels Hoisting Experts
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
ADMIN Andrew
ADMIN Andrew
Are you a Dayton Wire Wheels Hoisting Expert? Answer questions, earn points and help others
