I am trying to thread the machine and insert bobbin..
SOURCE: Janome memory craft 5700, purchased 2004
Take out your bobbin case and examine it for nicks, scratches and or rough spots.If the problem is not too bad it may be possible to buff out the bad spot with an emery stick or emery cloth. If that isn't possible or it makes too much noise after you buff it you will have to replace it. Look especially along the edges and underneath.
sewman7
SOURCE: machine will not pick up bobbin thread
Sounds like your needle is in too far and it not allowing the needle to go down far enough to pick up the thread.
SOURCE: The machine won pick up the bobbin thread, it jams when starting
wont pick up thread from bobbin
SOURCE: Is the bobbin suppose to spin?
attempt to tighten nut on the hand pulley.if not turn grabbed problem can be in transferred trough gears...
