My wifes parents used to own one. She thinks you pull table top off pole and pull pole out and lay table on existing lip and make bed using table as bed board. hopefully this helps
A.Most modern drafting tables are made from
steel because steel is really strong, but also portable. Old tables made
from wood were really strong but difficult to transport or move around. To make the table even easier to transport,
the surface is attached with screws that can be unscrewed.
Wooden beach chairs are foremost very beautiful! They are also very durable and will never rust and can handle a heavy amount of weight (around 300 pounds)
Hi Ken, Sounds like you need to to adjust your fence.I use the blade from a combination square.Place the steel blade next to the saw blade(between the carbide teeth).Next loosen the fence lock,loosen the two hex bolts on the rear pinion assembly so that the fence can move side to side.Move the fence up to the combo blade and adjust the fence and lock the fence lock.Check for blade and fence for true.Tighten the hex bolts at the rear pinion bearing assembly. Thank You for choosing FixYa.com.
You can make some plates from mdf or the like to "lift" the 6x9's up (can also be bought, but I can't remember were I bought mine from, was a while ago). just cut some mdf to take the speaker and cut about 1" around, paint or cover with material and screw through to the shelf.
