Korg D888 8 Track Recorder Logo
L
Larry Cook Posted on Jul 30, 2014
How Do I reset factory settings on Korg D888 - Korg D888 8 Track Recorder
2 Related Answers
Anonymous
  • Posted on Jan 31, 2012
SOURCE: hello there how can i
press knob 1 and 2 and rec at the same time , then power on , then knob bank D , power off and on ,,,,, ready
Greetings Gerrie ( Holland )
Anonymous
  • 430 Answers
  • Posted on Feb 12, 2012
SOURCE: Korg d888 power supply voltage
Click the link below :----http://wikisolutions.blogspot.in/2012/02/get-free-answers.html
Hou to reset to factory settings korg sp 200
You might search through the manual for the 20+ hits on the word RESET:
http://cdn.korg.com/us/support/download/files/e5fb7e3294b3843fc9633f45a0d23bef.pdf?response-content-disposition=inline%3Bfilename%2A%3DUTF-8%27%27SP200_EFGI1.pdf&response-content-type=application%2Fpdf%3B
May 12, 2018 • Korg Music
Why cant i connect to my pc anymore
If you have updated your computer OS it may no longer be compatable. Other than that do a herd reset on the Korg and see if that helps.
1helpful
I plug the USB from the D888 to my laptop (Toshiba Satelitte with Windows Vista) and nothing happens. The USB button is turned on.
Not a solution but a question that might get you closer to resolving this. Have you attempted to connect to any other computer with your D-888. Did this work?
I want to restore factory settings for the Korg PA 80
Give me the correct sequence to factory reset my Korg pa80
Feb 19, 2012 • Music
When my Korg d8 power is on 'working' message is followed by Init>?, I cannot go beyond this. How to solve this problem? And can I change the internal Hard drive.
It is asking for confirmation that you want to initialize the unit. The manual doesn't say anything about this... but you should try pressing the "Yes" button to confirm you want to initiallize the unit or press no if you want to staart without initializing.
D888 recorder/mixer wont boot up. Screen says "power on failure" initialize" appears that hard drive has failed. though I hear it running
The hard drive has probably failed. In spite of it rotating, the head servo and electronics has to work. I would recommend testing the drive in a computer to see if it works. You will likely have to reformat it after if it does work. FIRST look for obvious things in the D888 like cable that is partially off or loose.
2answers
Hi, I have a korg D8 recorder and that i use pretty regularly.One day i switched it on and it was completely dead - no lights, nothing. I've tested the power supply (the one it was supplied with ) and...
Most common cause are failed connectors. Power inout jack failures are common. Beyond that, tracing out the power input for a failure would be in order.
3answers
My korg x5 keyboard only turns on but nothing comes out of the display.nothing is loaded and no characters displayed.
Download the owners manual from here and try doing a reset to factory settings
http://www.korguksupport.co.uk/page.cfm?pageid=391#Owners Manuals
Feb 18, 2011 • Korg X5d
Top Korg Music Experts
john h
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you a Korg Music Expert? Answer questions, earn points and help others
