HP Photosmart C7250 All-In-One Thermal Printer Logo
Posted on Jun 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
You are not alone!
Nothing like going through a 50 page document to pull out every other blank sheet. (Not to mention having to add more blank paper in the middle so it has enough to print on!
Anonymous
Level 2:
Scholar:
  • Expert 100 Answers
  • Posted on Jun 30, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
100
Questions
0
Helped
46921
Points
289
Poshel nahuj pidaras
Will not print from the computer to the printer. I brought up a picture and pushed print and it just pulled in the paper and it was blank
* Check your warranty. Call for support.
*** Following is for information only.***
* Brand, Model for specific solutions.
* Computers and printers perform many functions.
* Just printing B/W documents are a thing of the past.
* Just printing a document requires the user to identify:
* Size of paper to be used. A4, 5x8", 8x10, banner, etc.
* Quality of paper; Plain, semi gloss, bright white, photo, etc.
* Orientation of document or picture; Portrait or Landscape
* Multiple copy.
* Size of document; Standard paper, Multiple (expanded) poster, Shrink (Reduced to fit page), Reduced to wallet size., etc.
* Color shift (effects) Print in grey scale.
* Print in reverse for T-shirt transfers or window posters.
* many more options depending on the printer. (some print on cakes)
* The point is that these or most of these have to be set up by the user EACH TIME you need to print something. The printer may be set for poster sized pictures but you just want to print a simple letter. This poster setting (depending on how many sheets per poster) may be the upper right corner of the document is blank. It did print but it started in an area that does not have anything to print.
* Another issue with printing (more common) is how many sheets are you printing. Depending on your CPU speed, each page needs to be processed (rendered) to be accepted by the printer. My Lenovo ideapad takes 2-3 mins to render 1 page. Printing 15 pages (or copy) takes over 30 mins to render before it prints the first sheet.
* Which order of print? Was the last page printed first? Is the last page blank?
* Wireless printers also take time to transfer data to the print buffer. This is also depends on your router or WiFi speed. (or network)
* To check your setup use the "Preview" option. Not how the document is pictured on the printed sheet. Pre-view saves on wasting paper on miss prints due to incorrect settings.
* Check your printer manual on setting up for a specific paper, document size, quality, and other issues.
Aloha, ukeboy57
PS, the issue of lost connection (WiFi) will stop the print. Eject the last page (partial print). Some machines will eject page only after a restart or reset.
* Perform a "Test Print" using the printer test mode (to check if the printer is out of ink.)
* Perform a print of a single page letter from the computer to test the connection to printer.
* Use the computer to check the printer app. look at the ink levels. Perform a system check of the printer operations.
Feeds a blank sheet of paper after every print job
check and see if your cursor goes to the next page after your last written one in your document. If so then backspace to your last written page so that the blank page disappears because having this page the computer takes it as part of the document but because there is nothing on it a blank page comes out.
The printer is feeding a blank sheet of paper between printed sheets. How do I rectify this?
This causes the printable area on the page to be that much less (10 3/4 or 10 1/2 on an 11 inch page). The software thinks the paper is 11 inches long and keeps track, down to the micro inch, where it is on the paper. When it reaches the 10 1/2 inches, your printer calls the page done and ejects it. However, the software thinks there is still another 1/2 inch to print (usually the footer area). Now when you insert a new sheet of paper, the software finishes printing the rest of the page (normally a blank footer) and form feeds to the next sheet. To correct what the software thinks the paper size is, you need to run the Preferences application and change the default settings. Select the Printer button. In the next window, select the 'Change Defaults....' button. Change both the Document size and the Paper size to a height of 10.875 and click OK. Try a new document to see if the paper size is correct. You may need to go back and change the height a few times until it is correct (the height changes in .125 increments). Usually either 10.875 (for 1/4 inch forced top margin printers) or 10.75 ( for 1/2 inch forced top margin printers) will work.
4helpful
Extra blank sheet of paper between printed pages
Check your print settings, it is possible that you enable page seporator in the settings.
Pulls in multiple sheets of paper
you must not use thin paper. you should use thick paper so that it will only pull one paper at a time...
I have an HP printer scanner 1310 series. Have trouble with printing. It will run about 3 blank pages through before it will print. Then it will run a page part way through so have to open back to get it...
Hi Audrey-
There are many things that will effect how your printer handles paper. The most overlooked being the size of the document or image to be printed. If the image or text bleeds over the edges (left, right, top, bottom) of the document, several sheets can be ejected before the "visible" printing takes place. Often those first few pages look blank, but actually are the outer edges of your picture or text. If you are printing a large picture or large text document, this may be your situation. Try printing a document with just a few words on it (like a small email) as a test.
The second most common culprit is dusty, dirty feed rollers in the printer. Consult your HP 1310 series manual for instructions on cleaning the feed rollers, or consult this general cleaning article on HP.com. HP PSC 1310 All-in-One Printer series cleaning
The type of paper can also effect how many sheets are pulled into the rollers. Is the paper new?, Thick?, Very thin?, or is it the same ol' printer paper you've always used? Either way, remove the stack of paper from the feed tray, "fluff" it by fanning it (like flipping through a book very quickly, or the way Superman counts a stack of money!) and replace. Print a test page.
Let me know if this helps!
2helpful
Designing a document in book form and printing in Word 2007
When you select Book fold for your page setup, Microsoft Word prints two pages on one side of the paper. When you fold the paper, it opens like a book. This option is intended for documents that have more than two pages.
1. Set up your document as a booklet.
When you create a booklet, it's best to start with a new, blank document so that you have better control over the placement of text, graphics, and other elements. You can add a book fold to an existing document, but you may have to reposition some elements once the book fold is in place.
A. Start a new, blank document.
B. On the File menu, click Page Setup, and then click the Margins tab.
C. In the Multiple pages list, select Book fold.
If your document is not set to landscape orientation, Microsoft Word sets it to landscape.
D. In the Inside and Outside boxes, type or select the amount of space you want for the inside and outside margins (margin: The blank space outside the printing area on a page.).
If you need even more space along the fold to accommodate binding, type or select the amount of space you want in the Gutter box.
E. In the Sheets per booklet list, select the number of pages you want to include in a single booklet.
If the number of pages in the document exceeds the number of pages you select for a booklet, Word prints the document as multiple booklets.
F. Select any other options you want in the Page Setup dialog box.
G. Add text, graphics, headers or footers (header and footer: A header, which can consist of text or graphics, appears at the top of every page in a section. A footer appears at the bottom of every page. Headers and footers often contain page numbers, chapter titles, dates, and author names.), and other elements to your document as usual.
2. On the File menu, click Print.
3. Set options for printing on both sides of the paper.
If you're using a duplex printer (one that automatically prints on both sides of the paper)
Click Properties, and then set the options you want. If you have a choice of setting the page orientation and duplex options, select landscape orientation, and flip the document on the short edge or short side.
If you aren't using a duplex printer
In the Print dialog box, select the Manual duplex check box. Word will print all of the pages that appear on one side of the paper, and then prompt you to turn the stack over and feed the pages again.
4. Select the page range you want to print.
If you click Current page or Pages, Word prints the page you indicate, plus the three other pages that belong on the same sheet of paper.
If you click Selection, Word prints your selection using the default page layout instead of booklet layout.
Blank pages
You might want to start by doing some general print quality troubleshooting, including printing a test page. The test page should give you an indication if you have issues with print cartridges. Also, some printers may not print at all if even one of their cartridges is empty:
Correcting Print Quality Problems
The other thing that occurred to me is that your document feeder could be pulling in more than one sheet of paper at a time, this means it would output blank sheets as well. Here's a web page that describes the problem and what to do about it:
Automatic Document Feeder Error
Hopefully the answer to your problem is available in those web pages. Good luck.
3answers
LexMark 5400 Series All-In-One Printer
To clear a paper jam:
  • Pull Carefully
    If the sheet of paper is visible at the output slot of the printer (in other word, it stopped on its way out of the printer), try pulling carefully on it. If it pulls smoothly and easily, then carefully pull it the rest of the way out. If there is resistance, then stop and go on to the next step.
  • Open the Cover
    Open the printer cover and wait (in the case of an inkjet printer) for the carriage to stop moving. Carefully, slowly pull out any paper that is caught there.
  • Take Care
    Do NOT pull paper out from where it was feeding into the printer (where the blank paper enters the device). The rollers on your printer may only go in one direction, and if you force them the wrong way, you could damage the machine.
Be careful of the following:
  • Laser Printers
    If you have a laser printer, be very careful when pulling out the paper -- laser printers can get hot.
  • Paper Shreds
    If any paper tore, either during the jam or while you were removing them, remove any appliances that you can (paper trays, etc.) and look for the shreds of paper. Try to make sure nothing has been left behind.
If you have frequent paper jams:
  • Don't Overload
    Overloading your paper tray can cause paper jams. Your manual may say that your input tray can hold 250 sheets -- but if you keep getting jams, try loading 225 sheets instead.
  • Check the Paper
    Check the minimum/maximum paper weights that your printer can handle. Paper that is too thick, or too thin, can cause jams.
Goodluck..
1helpful
3answers
Paper jam light is on
Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
k24674
Grand Canyon Tech
Grand Canyon Tech
