Question about Dell PowerEdge Computers & Internet
STRIKE f1 ERROR - PowerEdge Dell Computers & Internet
  • 36 Answers
Please be more specific. You haven't actually asked a question. What are you trying to do? What happens that you aren't expecting?
Posted on Aug 08, 2014
SOURCE:
Error code F1-15
You have a problem with tray movement in the finisher/sorter area. Sometimes those trays get slightly bnt if somebody leans on them and they dont strike the sensor in the center properly. If not then maybe the upper and lower limit sensors need to be cleaned or replaced
Jul 24, 2012 | Sharp AR-M350U Copier
I have dell optiplex 330 when i start it it need to strike f1 for boot f2 for setup and f5 for scanning
There could be two reasons you are getting this error message .
1. The operating system has crashed and needs to be reinstalled
2. The HDD has gone bad.
Run the diagostics on the computer.
Restart your computer at the Dell logo , tap on the f12 key slowly 1-3 times.
Using your down arrow key on the keyboard highlight IDE drive diagnostics or HDD diagnostics.
Press enter .
Incase there is an error , the hard drive needs to be replaced , else the operating the system needs to be repaired or reinstalled .
Thanks for using fixya
Proton
Jul 05, 2012 | Computers & Internet
I had my battery run out, when I changed I get a message that says Strike F1 key to continue, F2 to run the setup utility. When I strike F1 nothing happens, when I strike F2 I enter the bios and I change...
Hi, you will need to perform a windows restore using your windows CD. Insert CD in drive and select the appropriate option. You will not loose any of your work doing this.
Jul 30, 2010 | Dell Computers & Internet
Problem rebooting Dell PowerEdge Server 2600
ERROR 02A2: BMC System Error Log (SEL) Full
press F1 to continue or F10 to enter BIOS.
I wait for 2 minutes without doing any thing my server get started normally.
Please help me how to stop this error
Feb 19, 2010 | Dell PowerEdge 2650 Server
Strike F1 to continue, F2 to run the setup utility
Got to BIOS by pressing F2,check or any floppy setting and disable it even in boot order setup.This will solve your problem otherwise replace the lithium CMOS battery.
As you have reset the BIOS setting to it's default setting.Floppy drive is enable by default whether your system have a physical floppy drive or not.
Dec 24, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Please let me know what is the make and the model of the pc that you are using.. Also, go to the bios, under boot menu, make sure that you have hard drive as the first boot option.. For further queries please get in touch..
May 28, 2009 | Computers & Internet
Hi! my computer doesn't start normally it goes back to the same error every time. Errors: Floppy diskette seek failure Drive 3 not found: Parallel ATA,PATA-1 (PRI IDE Slave) Strike the F1 key to conti
Sounds like you have a bad/disconnected Hard Drive and the system is looking for a second boot device (ie: Floppy with a disk) or your primary IDE channel on your motherboard is bad
Apr 16, 2009 | Dell Dimension 3100 PC Desktop
Internal HDD hard error
By your description it is very likely your hard drive finally failed. You probably looking at total data loss unless you have made recently an backup of it. You will have to get a new HD and then you can install your OS and software.
Another more remote possibility is that when you opened some covers, you accidentally disturbed the HD connection causing this problem.
Just for clarification, was there a lot of dust inside ?
Hope this helps.
Jan 12, 2009 | Dell Latitude D510 Notebook
Dell latitude C610
From the Bios, load all the default settings and then check the bios SATA port settings. If it is set to AHCI, change it to IDE to boot from Hard Drive. This should solve the problem
Oct 01, 2008 | Dell Latitude D600 Notebook
No boot device available
I am using the dell system at XPS710 and i kept getting the bios error:
I tried to hit F1, then i get that message again. I hit F2, then it i didn't see the problem.
PLEASE HELP! 16x16_smiley-mad.gif No ignores!
Apr 27, 2008 | Dell Latitude C640 Notebook
Open Questions:
Computers & Internet Logo
64 people viewed this question
Ekse
Clive
Clive
Alun Cox
