Yellow toner empty
You will need to use the menu on the printer itself to change a setting
Press "Menu Select" button to get the menu function
Use the right arrow twice to select "Engine", then press the down arrow to the "Replace Toner" menu
Press the right arrow for the "Toner Empty" menu
Press the down arrow to get the Toner Empty settings
Press the right arrow to change the Toner Empty setting to "Continue"
Press the "Menu Select" button to confirm the setting.
You should be able to print, you just won't have any yellow toner.
When you get your toner cartridge, follow these instructions to reset the 'Toner Empty' setting to Stop so you will know when a toner is out.
