SOURCE: My laptop keeps saying media test failure and such
I had that and one of my ram modules was finished. Take it apart as much as you can and check everything is firmly in place. you can get new ram but it may not be ram it could be anything loose cable failure is the clue. As laptopps get bounced a lot you could well be lucky. Remove battery and power and take your jewelry off I use disposable gloves so I dont cause any shorts. While you are in there give your fan a clean. good luck.
SOURCE: computer locks when starting
I cannot be sure, but I think that this problem has something to do with having "boot from network adapter" enabled in your BIOS. If this is not the problem, then it might be another malfunctioning device, in which case, you will want to go into BIOS and disable everything except for what you need to get through the restore process(Disable USB ports, network adapter, PCMCIA card slot, etc.)
SOURCE: Broadcom UNDI PXE-2.1 v11.0.11 Copyright (C)
change your boot priority. press power button then keep on tapping F1 key until your reached to setup utility. go to boot menu and set your boot priority 1 to your HDD. if compute wasnt able to detect your HDD . then there is a problem wth your HDD, you need to call you manufacturer for HDD replacement if unit is still under warranty
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Hi. I think the problem on this one is its either your Harddrive has already failed or your Optical Drive has a cd inside, so double check your Optical drive if there is a disc inside it. If not this issue is also with the operating system, you can try to restore your system by pressing the One Key recovery(OKR) button found beside the power button which has a logo of an arching arrow, but remember to plugin first the ac adapter on your laptop before pressing the One Key Recovery Button and also do not press the power button to turn on your computer because when you press the OKR button it will automatically turn on your computer and proceed with the recovery process. When it gives you some option you should choose One Key Recovery and then choose System Recovery, then factory default and from there it will guide you to the whole process of recovering your machine. If this doesnt fix the issue you could also try using the Recovery disc to restore your sytem t its original settings just like the OKR. Lastly you can contact the tech support dept. of Lenovo, they are open 24/7 and this the number to contact:
US/Canada: Available 24/7 1-877-4LENOVO (1-877-453-6686)
Australia: Available 24/7 1300-557-073
New Zealand: 9am-9pm Mon-Fri 0800-446-833. Hope this helps
SOURCE: my laptop isnt working.as soon as u turn it on a
It goes to a network boot rather than booting straight to the HDD. restart your computer and press f2 immediatley. you are now on the BIOS page. check if your hard drive is detected and if not call Lenovo to have it replaced/repaired. if it is detected, after the PXE error, your computer should boot up just fine.
