How do i wire it for 220 ? i have a sanborn magna force comp.i have white,black & green power line. black & white from switch.the panal is numbers are 1 to 6
You can\'t run it on 220, but if you take only one of the 220 black wires and attach it to the black on the compressor you are feeding it 110. The problem will be that you have no neutral wire so you\'d have to use the ground of the 220 lead (green) as the neutral on the compressor (white). It\'ll run fine but it\'s not the right way and it can be a hazard. The white wire is neutral which is basically a ground wire from the electric company, the green is the ground wire in your building and it\'s there for safety so using it to power things is dangerous and probably illegal. I\'ve done it in a pinch, but wouldn\'t do it if at all avoidable. You may be able to get a transformer but you\'re probably better off running a 110 circuit or getting a 220 compressor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/oscar_403cc49e0f00cda7
