Ipad air
It's hard to identify the exact reasons that cause the iTunes error 4013 without a specific context. Before you solve the issue, it's better to figure out the possible causes. Based on research, here are the most commonly seen causes for iTunes error 4013.
Poor network
A reliable network is always required when you try to update or restore your iOS devices. It doesn't have to be a super network but just needs to make sure it's stable enough to connect to the iTunes update server.
iTunes version
Your iTunes version matters, especially when you use iTunes to update or restore your iOS device. The old version of iTunes might cause the iTunes error 4013 when connecting to the update server.
Broken USB connection
When your USB lightning cable is not properly connected to the computer and your iOS device, it might cause the iTunes error 4013. This is because the small plates at both ends of the cable are not touching those on your devices, hence the connection fails.
Low storage
Is your iOS device running low in space? If yes, it might affect the connectivity and cause the iTunes error 4013. An iOS update often needs to download firmware, which might require your device to have enough storage to proceed.
Source: https://www.leawo.org/tutorial/how-to-fix-itunes-error-4013-1361.html?fixya=1410
Ponder it for an hour or two, then make yourself a bowl of ice cream. Works for me.
SOURCE: reseting my IPAD
Hi There,
You have to enter DFU Mode (iPad LCD will be black) before restore, and
please follow this step by step to enter DFU Mode:
regards,
dm
