Aqua Products NE4275 Mamba Auto Pool Cleaner Logo
A
Anonymous Posted on Jul 28, 2014
Mamba goes in a circle - Aqua Products NE4275 Mamba Auto Pool Cleaner
Gets stuck on steps
There are a few things you can try to avoid the Mamba from getting stuck on your steps.
  1. Remove a section of hose and experiment with the length of hose used.
  2. Adjust the suction level to see if that helps.
  3. Try adjusting the weight so that the Mamba is unable to move as far up the walls.
  4. Put your pump on a timer, so it does not get stuck for a prolonged period of time.
Here is an incredible list of trouble shooting responses for automatic cleaners.
http://www.troublefreepool.com/archive/index.php/f-50.html
My new mamba aquabot cleaner will not move. It is tring to pluse but it want move
you are probably not getting enough water pressure thru the hoses. Check to see that the water is flowing strongly thru the hoses.
Jun 11, 2014 • Pool & Spa
4helpful
How do i install machinarium on my pc i just bought this game and nothing comes up to install on auto play and nothing in the files to install
The publisher of the English edition of Machinarium (Mamba) had a very serious problem with the duplication house they hired to produce the discs for their release. Namely: they didn't come out as hybrid PC/MAC discs but, instead, were all PC or all MAC. So some buyers have found themselves with MAC only disks and some with PC only (when they wanted the reverse... if you follow me).
What one has to do is to write to Mamba at: [email protected] and explain your situation. You will be sent a replacement disk in the format you require.
Soure: http://machinarium.net/forum/index.php/topic,806.0.html
Rust
spraying deisel on it will not keep it from rusting it will damage the bike
Top Aqua Products Water Sport Experts
ADMIN Andrew
ADMIN Andrew
johnny bonacci
johnny bonacci
Are you an Aqua Products Water Sport Expert? Answer questions, earn points and help others
