https://www.engine-codes.com > u1002_nissan
'What is U1002 NISSAN code meaning? ... The Diagnostic Trouble Code (DTC) sets when the Anti-Lock Brake System (ABS) Actuator and Electric Unit (Control Unit) is ...
P0101
What Does Code P0101 Mean? P0101 definition: Mass Air Flow (MAF) Circuit/Performance Malfunction. Issue Severity: MODERATE - Extended driving with this code can cause internal engine damage. Repair Urgency: Get this code fixed as soon as possible to avoid internal engine failure.Feb 21, 2022
Try alt+F10 when windows boot. else try restart your computer start tapping F8 once you see the advance boot options..go to repair my computer..select the language..then enter your user name and password..in recovery options go to factory image recovery.
Laptop computers can be wonderful devices, except when the need to troubleshoot arises. Acer laptops are no different. A quick way to fix many problems with an Acer laptop running Windows is to reset it to factory settings. Resetting your Acer laptop to factory settings can eliminate slow operating, registry problems, virus problems, spyware issues and more. And a factory reset of your laptop may reduce the need for a full reinstallation of Windows.
1.Back up all necessary data to an external device such as a disk, flash drive or hard drive
2.Make sure all programs are closed and shut down your Acer laptop by opening your Start menu and selecting "Shut Down" from the options for shutting down and restarting windows.
3.Detach any external hardware such as an external hard drive or printer.
4.Press the Power button to boot your Acer laptop.
5.Press "Alt + F10" on your keyboard when the Acer screen appears at the start of the boot up process. Wait a moment while Windows loads the reset files.
6.Select "Restore System from factory default" in the Acer eRecovery Management window.
7.Click "Next" on the next screen to continue. Click "Next" on the following destination information window. This will pop up a notice telling you that resetting your Acer laptop will erase all data and restore the laptop to its original settings and configuration.
8.Click "OK" in the notice window to proceed with resetting your Acer laptop.
9.Wait while your Acer laptop is reset to factory settings.
To restore your machine back to the factory settings, just follow the simple step mentioned below. Be sure that you've backed up your personal files though before doing
this because resetting your machine will wipre out any changes you have made on the machine.
For an Acer machine, just press Alt+F10 when you boot up the laptop. You will see Acer
Recovery Management, select "restore system to factory default settings" then follow the on-screen instructions and you should be good to go.
To reset your laptop to its factory state you need to restart or turn it on, then just tap F10, It will ask you on how would you loke to restore then select Restore system to factory settings. Usually it would ask you for a password just etern six zeros "000000" it should work. Please wait until the restore process is completed.
Note: All data will be deleted so make sure you back up them first before you do a Restore to Factory Settings
In order to reset your computer to factory setting you have to have the system restore disk and put it in your cd drive and reboot your computer with it inside... after pc boots up, a screen should popup click on restore to factory settings... if you dont have a disk reply back and i can give you a link for download..
Unlike
other laptops, Acer laptops integrate a computer management utility
called 'Acer eRecovery Management' to create backup of hard drive data,
create restore point, reinstall applications & drivers, and reset
Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3:When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to
reset your Acer laptop. This process will erase all data from your hard
disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If windows is running you can start it by going to Programs, Acer Empowering Technology and run the Acer eRecovery Management. Note that on the bottom of the eRecovery Management window are 3 choices, Backup, Burn Disk and Restore. Click on Restore. Here you have the choice of select Restore System to Factory Default.
If windows is not working but the system boots -
Reboot the system and when the Acer logo appears, hold down the ALT key and press F10. This starts the recovery process, just follow the instructions.
