Directv IR remote TV code for Upstar flat panel TV
0285,0288.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: Lost TV remote for Coby Flat Panel TV, 17inch
Universal remotes are not compatible with any Coby TV. You can get a remote directly from Coby:
Send:
$6 Money Order - 'Made out to Coby Electronics'
note with your name, address, phone#, model# and what part you need
Send to:
Coby Electronics
Att: Customer Service
56-65 Rust St
Maspeth, NY 11378
SOURCE: Program a universal remote for the Dynex 32" 720p Flat Panel
Try using the codes listed for Orion products. Worked for me.
SOURCE: getting stereo speakers to work with flat panel tv
if you hook the low-level audio-out from the tv to an input to the stereo unit, whatever you play on tv will send audio to surround/stereo reciever unit. look on back of tv for red &white AUDIO OUTPUT terminals. plug red/white audio cables from tv to the back of your stereo & plug into audio input of an open source on stereo (tv/video,aux. in,etc.) good luck!
SOURCE: directv remote codes
go to menu
setup
setup again
remote
tv
brand
the satelite receiver will tell you the procedure for programing the remote
SOURCE: I need a code list
Hello zaninc and welcome to FixYa. I'm not sure if you are referring to the codes for your cable box or your actual television so I have provided codes for both.
Panasonic Television Codes
0051, 0055, 0250
Panasonic Cable Box Codes
0000, 0107, 0021
Note if your remote control only accepts three digit codes you will have to take the first zero off of the codes that I have provided in order for them to work.
If these codes do not work for you please inform me of what make and model of set top box you own using the comments box and I will get right back to you. Thank you for using FixYa and good luck zadinc.
