Danby 3.6 cu. ft. / 102 liter Chest Freezer Millenium DCF401W Logo
A
Anonymous Posted on Jul 28, 2014
Whirlpool - troubleshooting
Wcn 3-8 cold but not freezing
Upright whirlpool freezer is not freezing. fan motor comes on, light comes on but is not getting cold. how can I trouble shoot the problem?
Could be the cold control thermostat that is the problem. You didn't provide your model number so couldn't get specific here. I did find another forum thread that might give you more clues: http://www.applianceblog.com/mainforums/threads/36458-Whirlpool-freezer-cold-but-not-freezing
Sep 18, 2014 • Freezers
Freezer is not freezing
Good Morning Friend,
I understand that your Frigidaire freezer is not getting cold enough to freeze your food. I suggest cleaning the compressor, underneath your appliance, by using an attachment on your vacuum. I also suggest lowering the temperature and giving your freezer 4-24 hours to stabilize at that temperature. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dishwasher status has changed successfully. If further troubleshooting is needed, please leave me the model number of your freezer. Hope this is helpful.
-Best Regards-
WP
2answers
Whirlpool freezer cool air but not freezing?
Check the seal first. Then check the freon. If it's R-12, you can go to the auto parts house. They have a bottle with a hose to add freon. You put it in on the "suction" low side with the unit running. you can tell when it has enough by feeling the low line be cold and teh high pressure line is warm to hot
Top 3 shelves don't freeze
Cold air sinks. If evaporator temp is not low enough only the items on bottom of freezer will get cold and possibly freeze - stuff on top will not.
Throw a digital thermometer in there towards the top shelves and I bet your temps are high. Low refrigerant will cause this; furthermore, if you leave the refrigerator door open by accident, the refrigerator will never shut off, the freezer evaporator will freeze over with a block of ice, and the freezer temps will be higher. If that is what happened, simply unplug the unit and allow it to self defrost and then turn it back on for proper operation and make sure that the refrigerator door is properly closed!
I have a whirlpool upright freezer,model EVL181NXTQ.There is a buzzing noise and the top half doesn't freeze..When you close the door,uou can hear the suction sound...Please help,freezer is only 2 years...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
My freezer will not freeze. It only gets cool.
heatman101
Whirlpool ED25RFXRWFreezer/Fridge temps unstable...either too hot
check the defrost timer but the cold control could be bad
Side byrefrigerator runs but not cold. Freezer is
take everything out of it, and let it thaw for 24 hours, using towels and whatever to clean up the water......then plug it back in, if it still does it, like 2 days later, it's broke, if it doesn't it was just the coil in the back that froze up. Happened to me.
The top of the freezer is not freezing.
Normal 0 If the bottom of the freezer is freezing (but only just), but the top is just above freezing, then your problem may be either your defrost timer or the defrost heating element. You'll need a thermometer to determine how cold (or not cold) your freezer is getting. Usually a freezer is happiest when it's full, so being too full is likely NOT the problem (there is room for air to circulate, right?).
If you're handy, you can troubleshoot the problem yourself by following the suggestions found here, as that may at least identify the problem. Replacing components inside your refrigerator isn't incredibly complicated, but if you're uncomfortable with taking things apart, you may be better off seeking the help of a properly trained professional.
Hope this information helps!
Aug 24, 2009 • Freezers
Freezer gets cold but doesn't freeze
check tem.p inside cabinet and let us know what you find
Jun 29, 2009 • GE Freezers
Top Danby Freezers Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Thomas Perkins
Thomas Perkins
Are you a Danby Freezer Expert? Answer questions, earn points and help others
