Sounds like a belt slipping when it shifts from 1st to 2nd? and i have to give it more gas and then let off to let it catch and not slip?
Check the fluid level. You may want to consider having the transmission flushed. (I recommend BG Products flush system.) Properly flushing the trans removes any varnish the may have built up causing erratic behavior.
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Automatic transmission shift lever
issues?-------
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
AUTOMATIC TRANSMISSION FLUID LEVEL? --
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-automatic-transmission.html
AUTOMATIC TRANSMISSION FLUID AND
FILTER?
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-automatic-transmission.html
Transmission fault light on
car dash?
http://schematicsdiagram.blogspot.com/2011/12/transmission-fault-light-on-car-dash.html
Transmission shifting
problem?
http://schematicsdiagram.blogspot.com/2012/01/transmission-shifting-problem-on-toyota.html
Transmission Slips out of 2nd gear?
http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
OD light flashing and transmission fluid
leaking?
http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html
Why Transmission fluid leaks near radiator?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
Transmission fluid leaking?
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
****** wont go in reverse?
http://technoanswers.blogspot.in/2012/02/dodge-neon-wont-go-in-reverse.html
Automatic transmission will not go into
reverse?
http://technoanswers.blogspot.in/2012/02/dodge-automatic-transmission-will-not.html
Transmission is making buzzing noise?
http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
This
will help.
Thanks.
