There are two parts to the 'float valve' pin which has fallen out.
The pin itself pushes back in from the underside of the pan lid,
BUT,
there should be a clear silicone grommet or washer, which slides over the pin from the outside. This is what holds the 'float valve' pin in place & stops it falling into the pan in use.
If you've lost the original grommet in the washing-up, there might be a spare which came in the original box with the pan.
If not, you can order the replacements from the manufacturer or on eBay.
(https://www.ebay.com/itm/Float-Valve-Sealer-Power-Universal-Pressure-Cooker-XL-YBD60100-PPC780-PPC770-New/302469900126?hash=item466c9c675e:g:A7QAAOSwkRpZpszq)
Best of luck.
Tracy, Check the attached links or try google search your make replacement pressure valve. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." Pressure Cooker Parts Pressure Cooker Parts Fagor America Shop
Rather than online, I would try to contact the manufacturer, as with any pressure-cooker, having the exact right parts, particularly for the pressure valve, is critical for safe operation.
If you do not see your model number for your product, suggest you contact their Customer service at 1-800-275-8273 to determine if the Instruction Manual for your model is available. Alternatively try making an inquiry via their webform:
Replacement parts for the Wolfgang Puck pressure cookers are difficult to find and I just received an e-mail back from an earlier inquiry to the the company advising that parts are available here:
Not sure if your model is the BPCR0175 but if the part you require is not available on-line suggest you contact their Customer Service at 1-800-275-8273 or make an inquiry via their webform:
If you do not see the parts you require or are unsure about the model number; suggest you contact their Customer Service at 1-800-275-8273 or via their webform at:
If you do not see the part you require or are unsure about the model number; suggest you contact their Customer Service at 1-800-275-8273 or via their webform at:
