When I lower the needle to pick up the bobbin thread, the top thread keeps getting wrapped around the bobbin case.
I have looked on Brother.com for a solution and there are no related issues on their site.
I am desperate at this point.
Any help would be appreciated.
Thank you.
When it gets wrapped up - it's because you are turning the Wheel to many times - the bobbin should make a little more than half a turn and then you should be able to get it up by pusling the upper thread.
If the upper thread do not cache the under trhread - then try to change the needle
good luck
My tread keep cutting
You should hold the end of the thread coming through the needle until the thread has grasped the bobbin thread.
